Added .015, then .025 in PE vs. RPM table and 02's went DOWN from 905ish to 885ish??
Does that make any sense? It was cool and dry out on the later runs, but the computer should adjust for that, right? I'm a bit confused. I was shooting for 920ish since I run the car hard at the roadcourse for 30 minutes at a time.
I don't know why it went leaner, but it's not a ton of fuel. I'm sure you know the mv readings aren't that accurate as 885 was like 12:1afr on my last pull. .25pts on my PE table was worth about 1pt of AFR.
So if I only added .040, than it might be only about .16 pts of AFR. That's good to know how slight of changes I'm making.
Originally Posted by pknowles
Do you have COT enabled? After doing a few WOT runs, COT protectection started making things very rich for me.
-Dennis
