IAC position vs effective area
Maybe I just need to think about this some more...for whatever reason though, my car's idling problems have been cured.
1) cam
2) throttle set screw (or :shudder: drilling the TB blade hole bigger)
3) idle speed
The base running airflow controls how much the IAC opens at idle, the cam requires you to crack it open further, and raising your idle required you to crack it open further. This will usually put you beyond the IAC's capability to compensate, so you crack the throttle blade with the set screw. This can be used to put you close, but you will often end up with ECTs at which your car will not idle properly. The way to calibrate that is through the base running airflow table. You can adjust it close with your trims (I usually put mine a hair higher than it needs to be), but it worked out best after I did that and then poly smoothed it. I hope that answers your question without completely hijacking the thread.
The computer knows the IAC is open less, but doesn't know the tb is open more so you have to tell it that by changing the table.
table to the left is, if you went and got / made a
TB with the IAC ports filled and a bleed-hole drilled
for the IAC air passage, that hole is smaller than
stock. You will have less than expected air for a
given IAC position in that case.
so you cant use that table to compensate, makes the IAC open too far so it really has no room for error. so you crack open the TB and now you have the problem that the computer is still opening the IAC and doesnt realize you are actually letting more air in. so you have to tell it that it can close a little more??
another_user, you said you use the trims to measure this? im going to pm you about this so we dont take up 2 pages trying to get this through my head lol
on start up IAC position was 157 but then when the car warmed up it dropped down to 35-45 in that range, should it be that high on initial cold start or no?!
my idle doesnt drop, the desired was lower than dynamic, and i adjusted and the idle slightly hung on the first switch at 900-1050 rpm but it doesnt dip below the set idle anymore. idle seems much smoother.
if you guys could comment on the cold start IAC i would appreciate it, i dont know if thats normal or not.
the IAC vs effective area table goes to 120, now i was getting readings at idle of 157, is that what those readings are, on the top, for IAC position as in the PID readout?
HOLY ****...I never would have thunk it. RAF in drive at 177 is 12.5....desired airflow and dynamic airflow are both 1.66 which calculates to 12.58...Damn that's some cool ****.
