Dynamic Cylinder Air Chat
The MAF airflow reading is independent of the IAT sensor reading. The DA calc relies heavily on the IAT, which makes SD operation very dependent upon it as well. IAT only indirectly affects MAF operation through the DA calc that's used to filter the MAF reading during throttle transients. Also, I've seen your logged IAT when your trims take a ****, and it is steady.
O2s are kind of "soggy". I see very little change in the injector
PW despite gross changes in the STFT. I see the O2s swing up
and stick high with minimal change in air or fuel. The STFTs start
to accumulate negative "momentum" while the O2s are below
0.5V in some cases. This is just not sane.
This looks like behaviors I have seen in circuit designs where
a closed loop is being driven outside linear operation, saturates
& relaxes back, all on a timescale well outside the designed
stabilization frequency corners.
Did you mess around the proportional O2 stuff? I wonder if the
filter params might have changed to some values that destabilize
the loop?
Still I don't see why that would have a MAF/SD dependence,
other than that the two tunes might be differently mixture
biased and one might avoid the "trouble spot" by being leaner
or richer?
the loop?
or richer?
edit: Well apparently the MAF only puts out a frequency signal based on what it reads, so if the frequency is not changing when the trims drop, it can't be a bad MAF. Oh well.
I don't get it. Anyways, I just eliminated the PCV as the problem also.
1) MAF (borrowed one from a friend, same result)
2) COT
3) EVAP
4) PCV
5) MAF Table
6) VE Table
7) O2 Sensors
Soooo....should I do a complete reflash of the PCM? The only things left are PCM and electrical issue to the MAF.
Rick
Rick
