Ok To Settle The Svo Injector Ratings
MAP (kPa) 0 5 10 15 202530354045505560657075 80
Injector Flow (g/sec) 6.15258 6.190924745 6.229033451 6.266910425 6.304559843 6.341985758 6.379192104 6.4161827 6.452961256 6.489531379 6.525896571 6.56206024 6.5980257 6.633796174 6.6693748 6.704764631 6.739968642
Injector Flow (lb/hr) 48.83086114 49.13518988 49.43764526 49.73826147 50.03707164 50.33410795 50.62940161 50.92298295 51.2148814 51.50512559 51.79374332 52.08076163 52.36620682 52.65010447 52.9324795 53.21335613 53.49275797
Injector Flow (lb/min) 0.813847686 0.818919831 0.823960754 0.828971024 0.833951194 0.838901799 0.84382336 0.848716383 0.853581357 0.85841876 0.863229055 0.868012694 0.872770114 0.877501741 0.882207992 0.886889269 0.891545966
do i need to modify these at all??? will the car idle fine or do i need to take out some at lower KPA or anything like that?
Reason I ask is because my fuel psi jumps from 60-66 psi. I have a 255 walbro installed. I also have a fuel pressure gauage inside the car.
