Ok To Settle The Svo Injector Ratings
0 280 150 558
These are the part numbers on the green tops I have in front of me.
http://users.erols.com/srweiss/tableifc.htm
That is a site that shows lots of injector info.
Ryan
that link shows them at 40# @ 43.5psi , if im reading it right.
so is it 41.47 @ 40psi or something different?
Has eveybody been going with the 41.47 @ 40psi?
thanks
scaling using a constant multiplier is incorrect since flow rate is not linearly proportional to pressure (it goes as the square root);
it's correct (and easy enough) to calculate using the spreadsheet.
This is a big factor in all of this.
I have found Chris Bs spreadsheet for SVO 30s on the the LS1 Edit Faq website
Its based on the Ford offsets
At the Voltages 6, 8, 10, 11, 12, 13 ,14, 15 ,16 and at O pressure
4.6475
2.1182
1.3965
1.1973
1.0313
0.9033
0.7861
0.7148
0.7148
How much can we trust these values??
I have a spreadsheet of numbers i can try.
e.g. at 13.0V it is
0.899079
0.99541
1.091739
1.12385
1.155959
1.18807
1.18807
1.18807
1.220179
1.220179
1.220179
1.25229
1.284398
1.284398
1.316509
1.316509
1.316509
does anybody know if there is a sure way to tune the Injector pulse widtch?
there is a spread sheet from bosch with part numbers and all to find the real rating of all the injectors, the flow rate of them. as for the offset that is another story
My real question is, what other tables need to be tuned besides IFR table after going to bigger injectors
This is going from the stock offset voltage and millisecond values
to ones for an SVO injector.
Here they are
11.5-12.0-12.5-13.0-13.5-14.0-14.5
0.926358 0.861813 0.802884 0.749232 0.700744 0.65773 0.621406
0.94778 0.881742 0.821451 0.766558 0.716949 0.67294 0.635776
0.969202 0.901672 0.840017 0.783884 0.733153 0.68815 0.650146
0.990624 0.921601 0.858584 0.80121 0.749358 0.70336 0.664516
1.012046 0.941531 0.877151 0.818536 0.765563 0.71857 0.678886
1.033468 0.96146 0.895717 0.835862 0.781767 0.73378 0.693256
1.05489 0.98139 0.914284 0.853188 0.797972 0.74899 0.707626
1.076312 1.001319 0.932851 0.870514 0.814177 0.7642 0.721996
1.097734 1.021249 0.951418 0.88784 0.830382 0.77941 0.736366
1.119156 1.041178 0.969984 0.905166 0.846586 0.79462 0.750736
1.140578 1.061107 0.988551 0.922492 0.862791 0.80983 0.765106
1.162 1.081037 1.007118 0.939818 0.878996 0.82504 0.779476
1.183422 1.100966 1.025684 0.957144 0.8952 0.84025 0.793846
1.204844 1.120896 1.044251 0.97447 0.911405 0.85546 0.808216
1.226266 1.140825 1.062818 0.991796 0.92761 0.87067 0.822586
1.247688 1.160755 1.081384 1.009122 0.943814 0.88588 0.836956
1.26911 1.180684 1.099951 1.026448 0.960019 0.90109 0.851326
Others have used similar numbers.
Does anyone know what the risk is in trying them - if they arent suitable what will it do to try and see???
Or is this just for folks who are starting out and would then know they have the right values from the start to start tuning with.
Think I answered my own question but curious on thoughts....
BUT i did confirm something valuable for everyone.
On the dyno the other day had the dynologs computer hooked to my injectors and the duty cycle values matched precisely the ones i was logging in efilive. The afrs also matched my wideband values etc. I am using the injector flow rates that are set for them being 30 at 40psi - so i think this confirms they are right?
Ryan
But the dynolog computer was able to pick up duty cycle and rpm from wires on the injector.
We later also had an inline fuel meter which logged fuel in Litres/minute
Here is some data
At 6092rpm 253rwkw unlocked
Road speed 189kph
2.14 Litres/min at 50.8Hz InjF and IPW 15.1ms
AFR 12.30
Fuel Pressure PSI 58.9
Duty cycle was 76.9%
Interestingly 4.1mpg
My flow rates at WOT are 4.554688 g/s
and 4.578125 g/s at 0 and 5 Kpa manifold pressure
so that is 273g/min which is 363.5ml/min x 8 = 2.908 litres/min at 100% DC
at 76.9% DC this comes to 2.236 L/min
This figure actually supports the idea that the injectors are 34.5Lb so rated at 43.5psi.
So within one message i show a contradiction.
Can someone else confirm my figures???
BUT my car is only getting 2.14L/min of fuel.
what was your dynamic airflow or MAF reading at that rpm point?
i think the variation is small enough to chaulk it up to measuring errors.
read http://redhardsupra.blogspot.com/200...ctors-are.html
and you'll find out how small differences quickly accumulate
