Ok To Settle The Svo Injector Ratings
Old May 25, 2005 | 09:29 AM
oange ss's Avatar
everybody needs to verify their fuel pressure, I get 58 psi at cold start idle but after driving around it drops to 55 psi for hot idle
Old May 25, 2005 | 09:34 AM
RedHardSupra's Avatar
how do you do that? extra gauges, or does the pcm know it somewhere and we just need to extract it?
Old May 25, 2005 | 09:46 AM
oange ss's Avatar
fuel pressure guage
Old Jun 1, 2005 | 03:27 PM
horist's Avatar
TTT, adding to sticky
Old Jun 1, 2005 | 03:29 PM
ok, one final question:
prior to the installation of my svo30s, i had my VE dialed in just about perfect.
i installed the injectors, put in the calibration based on the 43.5psi original rating, and the ve stayed perfect.
if 40 is the right number, not 43.5, wouldn't my VE post IFR calibration visibly off?
Old Jun 1, 2005 | 03:37 PM
oange ss's Avatar
my VE table was virtually unchanged when i went from stock 28 lb injectors to SVO 30 lb injectors using 43.5 psi, I changed to 40 lb and everthing is showin lean
Old Jun 1, 2005 | 06:26 PM
jimmyblue's Avatar
Moderator
Changing injectors should produce no airflow changes
at all, and need no VE adjustment. Unless the new
injector has a very different snout, sticking into the
port or something.
When you changed the fuel model on the new delta-
rating-pressure basis you increased the flow value
and the PCM figured it needs less of it so you drift
lean in result.
Your actual system pressure vs 40 PSI should give you
an accurate fuel delivery scaling (as accurate as your
measurements and Ford's ratings). Fuel model doesn't
do a good job with the line losses (pressure drop @ flow)
though. Short pressure also makes short fuel.
You don't want to be in the position of tuning VE and
injector tables at the same time, with the same data.
That's one equation minus two unknowns equals one
headache. If you have to go there, then take on the
"easy" one (the injectors, where you at least have some
sort of standard ratings and can take the fuel pressure
reading pretty simply / cheaply) first and let the VE
hold the bag on any residual error.
Old Jun 2, 2005 | 10:57 AM
PewterZ28's Avatar
So if I have SVO 30# injectors and I am seeing 58 PSI fuel pressure, I should enter the following values in the injector scaling calculator?
Injector Rated Fuel Pressure: 40
Your Fuel Rail Pressure: 58
Injector Rated Flow Rate: 30
Then I change the MAP table according to the values the calculator gives me?
Old Jun 2, 2005 | 12:09 PM
99FormulaWs6's Avatar
That's what I've done, Pewter now I can't say that's 100% b/c I haven't gotten a chance to burn that yet.
Old Jun 2, 2005 | 01:29 PM
oange ss's Avatar
change IFR values not MAP
Old Jun 2, 2005 | 01:53 PM
Oops should have read that a bit better, I had changed my IFR not my map.
Old Jun 3, 2005 | 09:25 AM
  #32
PewterZ28's Avatar
My bad. I meant IFR table.
I'm having issues with this calculator. The numbers it yields seem backwards and too high.
Here's the problem. I found some old threads that said to multiply the IFR table by 127% for SVO 30# injectors. The stock values are higher in the lower tables and lower in the higher tables. So multiplying by 127% does not change that. However, when I plug in the numbers in this calculator it yields lower numbers in the lower tables and higher numbers in the higher tables. Completely the opposite of the stock configuration! No to mention the final table in the calculator goes from 0kpa to 80kpa but in LS1Edit the table is from 100kpa to 20kpa. Right now I don't have much faith in this calculator. Unless of course, multiplying by a constant is incorrect.
Anyone care to explain why the Final Table numbers yielded in the calculator increase opposite of the stock numbers and why the table is from 0 to 80 kpa?
Old Jun 3, 2005 | 10:01 AM
  #33
txhorns281's Avatar
Ok at 0 kpa (vaccuum) this is when you are at WOT, pulling 1 full bar. This is when your injectors will flow at their rated pressures. When throttle is closed/partly open you are pulling motor vaccum. 50 kpa vaccuum is = to 50 kpa MAP. Total vaccum + MAP = 1 bar (100 kpa). At part throttle the vaccuum pressure "sucks" more fuel through the injectors, hence why at greater vaccuum, you see a slight increase in flow rate. Your IFR should start at 0 kpa, with the calculated flow rate from doing your math, and gradually increase with greater VAC KPA.
And to add my own experience, I tuned up some SVO 30#ers last week on a friends car, did calculations according to 40 psi, scaled an 01-02 IFR table, and the result was PERFECT. We set everything up for open loop wideband VE tuning just in case, but the IFRs referenced produced 12.8-13.3 while commanding 13.0 all over the VE.
I'm about to try some 42#ers myself next week, I'll post back.
Here's the math I used:
(58/40)^.5 X 30 = 36.12 lb/hr @ 58 psi (LS1 standard)
36.12/26.4 OR 28.7 = 1.368
Scalar for 99-00: 1.368
Scalar for 98,01-02: 1.258
Last edited by Ragtop 99; Jun 8, 2005 at 07:57 PM. Reason: Made the scalars easy to find (hope you don't mind ;) )
Old Jun 3, 2005 | 10:25 AM
  #34
txhorns281's Avatar
port or something.
lean in result.
Old Jun 7, 2005 | 07:59 AM
  #35
SMOKINV8's Avatar
Wow, that would explain some things that I've run into. I'm running 60psi instead of 58, but this is a pretty considerable difference...
My old calcs:
4.36 | 4.39 | 4.42 | 4.44 | 4.47 | 4.50 | 4.52 | 4.55 | 4.57 | 4.60 | 4.62 | 4.65 | 4.67 | 4.70 | 4.72 | 4.74 | 4.77
New calcs:
4.63 | 4.66 | 4.69 | 4.71 | 4.74 | 4.77 | 4.80 | 4.82 | 4.85 | 4.88 | 4.90 | 4.93 | 4.95 | 4.98 | 5.01 | 5.03 | 5.06
I'm assuming this will lean me out considerably?
Old Jun 7, 2005 | 06:22 PM
  #36
txhorns281's Avatar
My old calcs:
New calcs:
more than likely noticeable... Go out and have a look for yourself
Old Jun 7, 2005 | 06:58 PM
  #37
SMOKINV8's Avatar
I'll have to post up a log of driving with the old IFR and with the new one, before any VE changes, just as a reference.
Now all I need is the free time outside of work and/or school.
Old Jun 8, 2005 | 09:22 AM
  #38
SMOKINV8's Avatar
Both of these were with DFCO enabled, so they may not be the best examples. I didn't disable DFCO when I did my first log a while back though, so I wanted to keep it an even playing field. The first log is also very thorough, compared to a couple 10-15 minute drives last night for the latter.
www.unrealhp.com/log.hpl
www.unrealhp.com/logpostIFR.hpl
www.unrealhp.com/logpostIFR2.hpl
The car did feel smoother with the new IFR though.
Old Jun 19, 2005 | 05:07 PM
  #39
i hate to bring it up again, but this is now two separate cases for me pointing me to believe that both svo 30s and 42s are rated at 43.5psi.
My car's VE table didn't twitch when I scaled the IFR using the 43.5 psi on a 26.4->svo30 swap. Now I did friend's car going 28.8->svo 42 and the VE table was perfect again after the swap.
once is an accident, twice is a coincidence...now i just gotta try a 3rd car, and we'll have a rule
Old Jun 19, 2005 | 05:31 PM
  #40
slow's Avatar
what is a vehicle that comes factory with those 30# injectors?
not trying to throw this thread totally off course, but ford uses a 2 slope rating system. With a low slope, high slope, and a break point where it changes between the 2.
Here are the actual values as found in a CXN1 lightning, 2001-2 approx model year. These come stock with the lime green SVO 42# injectors.
The values are:
High Slope 40.680
Low SLope 48.961
Fuel_Injector_Pressure_Drop 39.699
This shows these injectors when being used at 39.699# delta P to flow 40.68 #/hour for the high slope. (high fuel demands) If you convert them to 43.5 # delta P, the flowrate becomes 42.58 according to my hptuners calculator.
Ryan
