Where does WOT start?
Old Jun 2, 2005 | 08:42 PM
Blown Interceptor's Avatar
Default Where does WOT start?
At 0.52 G/CYL Or 0.56...in tuners?
Thanks,
Jason
Old Jun 2, 2005 | 08:45 PM
SmokingWS6's Avatar
Wot is wot. I assume you mean when it changes to PE fueling? IT depends on throttle position and rpm.
Are you trying to make timing changes?
Old Jun 2, 2005 | 08:53 PM
Yes, I spray(100Wetshot) at 3700 rpm. I wanted to lower the timing when it first sprays to see if I get rid of my detonation problem. I really want to bump it up to a 150 shot, but the detonation is way too much.
Thanks,
Old Jun 2, 2005 | 09:17 PM
WS6FirebirdTA00's Avatar
go out and log a wot run and see where your airflow is at
Old Jun 2, 2005 | 09:22 PM
I have a couple WOT throttle runs with EFIlive. Excuse my ignorance, what do you mean by airflow?
Old Jun 2, 2005 | 09:23 PM
g/cyl you can log that and when you see 100% throttle see what that reading is. but make sure you log g/cyl and not g/sec
Old Jun 2, 2005 | 09:34 PM
Here is a print screen of a quick run...the air flow got as high as 36.
Is this what you mean?
Thanks,
File Type: doc
Old Jun 2, 2005 | 09:45 PM
no thats the maf rate or dynamic airflow, you want to see what it is in g/cyl, that is measuring in g/sec, there should be a parameter to select for g/cyl
Old Jun 2, 2005 | 09:46 PM
your car could be different but my wot i adjusted .60 g/cyl and up
Old Jun 2, 2005 | 09:52 PM
Thanks for the help man! I really appreciate the help...I know this may be a stretch, but could I email you my tuner file and start me in the right direction? I made a few changes, fans, idle. I was pretty good with edit, but this looks to be SOOO much more than edit.
Thanks alot for the help!!!
Jason
Old Jun 3, 2005 | 04:58 AM
i have hp tuners so i cant read the file or else i would
Old Jun 3, 2005 | 09:26 AM
Thats what I am using as well, HP Tuners.
Jason
