02 Sensor readings question.
Or... will it just take longer to heat up and still read accurately (a relative term in regards to narrowband 02's)?
Thanks guys!
Hmmm. More thoughts? Ideas?
you bogus + LTFTs at lower airflows. The heat
at the sensor depends on multiple factors, the
plumbing geometry and the exhaust gas flow,
temp, and the outside temp / road airflow too.
The O2s will heat up and cool down, go in and
out of hibernation. This will drag the trims around
and give you a driving history effect, car runs
well and then runs poorly, etc.
O2s barely warm enough to work, will be slow
responding and the short term trimming effect of
this aggravates idle surge / wandering.
Talking about lazy 02's my bank one switches rather fast back and forth but it seems bank stays constant for a couple of seconds thens switches. Lets say it stays at 700 for about 2 seconds then takes a switch and gets stuck at 700 is this a bad sensor or is it normal?
Oh yea they have 70000 miles on them
I'll throw the Vette 02's in the headers and hopefully I'll be a little closer to seeing what my 02's are really reading. Doing PE adjustments and watching your 02's move only slightly makes me nervous the lower I go!
