*** Update 90mm TB + 48% Effective table
Could you send me the WHOLE explanation of the *0.48 thing? I'm not seeing it right now, could you take me through the process?
For a 90 mm TB a value of .0320 works well for most.
Ported 78 mm TB would be between .0255 and .0320 ??
also where in efi live is that scaler...I'm under idle and I see IAC area, idle speeds, start up correction, idle airflow, idle airflow parked....etc
Cool, thanks!
I thought .48 was the value used???
