What VSS values?
Old Jun 18, 2005 | 04:55 PM
GTS346's Avatar
Default What VSS values?
Can somebody tell me how many pulses per revolution does the factory PCM require?
As I need to buy a VSS for a TH350 conversion.
Old Jun 18, 2005 | 06:43 PM
P Mack's Avatar
Should be 17 on a 6 speed, 40 on an automatic.
Old Jun 18, 2005 | 07:23 PM
GTS346's Avatar
So it doesnt matter if its a 2, 3 or 4 speed auto, as long as you get a 40 rev speed sensor it will work, no OD.
Old Jun 18, 2005 | 09:11 PM
P Mack's Avatar
It's not the transmission that matters. If you have a computer from an automatic car it's gonna be programmed for 40, if it's from a 6 speed it'll be programmed for 17. And if you have a tuning program it doesn't matter cause you can change the value. Hope this helps.
Old Jun 19, 2005 | 02:49 AM
GTS346's Avatar
My car has been tuned and will be modified again thru HP Tuners, does this mean I can use any Sensor even a 2 pulse per rev sensor?
Old Jun 19, 2005 | 10:44 AM
P Mack's Avatar
Yeah, I tried putting 2 in the value in hptuners and it accepted it. Your speedometer might act jumpy at low speeds with that low of resolution though.
Old Jun 20, 2005 | 07:53 AM
GTS346's Avatar
Did it stop low speed surging and stalling problems normally assosciated without running a sensor?
Is the speedo accurate when cruising along?
Any other symptoms?
Old Jun 28, 2005 | 06:15 AM
GTS346's Avatar
My car does have a manual computer so it reads 17 pulses but all I can get in the way of aftermarket inline speed sensors for a TH350 is a 16 pulse.
Will this be accurate enough without changing the values?
Old Jun 28, 2005 | 09:51 AM
P Mack's Avatar
It'll read 80 when going 85. Is your differential gonna be 3.42?
Old Jun 28, 2005 | 04:28 PM
GTS346's Avatar
3.50:1 how far out will it be at 60 mile per hour?
How do I calculate it?
Old Jun 28, 2005 | 06:08 PM
P Mack's Avatar
If I did my math right it will read 58 when you're going 60 with 3.50's, 16 pulses per rev, 26" tires and a stock m6 pcm. I used:
speedometer reading = actual speed * actual gear ratio/programmed gear ratio * actual pulses per rev/ programmed pulses per rev * programmed tire diameter / actual tire diameter.
Old Jun 29, 2005 | 07:30 AM
Uk Robert's Avatar
GTS346, where did you get the in-line speed sensor from and how exactly does it fit in-line. I`m building an LS1 powered Ford Capri with a TKO 5spd and would much prefer your arrangement rather than a reluctor wheel on the prop-shaft etc.
Old Jun 30, 2005 | 05:30 AM
GTS346's Avatar
I havent yet, all the inlines I found were for hall effect setups, we need a magnetic pickup 2 wire, I am working on something, will hopefully figure it out with the next week or so. let me know if your still stuck.
Old Jun 30, 2005 | 07:27 AM
Uk Robert's Avatar
I`m still trying to get to grips with this speed sensor thing. Anyway see my post in Hybrids/Conversions re reluctor wheels etc etc....!
