Anyone ever figure out hot start issues?
Phil
Phil
Yeah that table made my life hell aslo
Edit that table seems kinda backwards to be. I mean for and allready hot engine you should need little to no enrichment after you start the car. THe fuel is capable of vaporizing on its onw with those engie temps. THey should be 0'd from the factory..... I can understand -40-68* but all the way to 284 is ridiculous.
Under afterstart enrichment did you zero out the three Decay tables above 120 degrees or just the initial adder vs. etc? I'm working on a getting a large cam to hotstart.
I multiplied mine by .90 until it looked somewhat similar to my primary ve table
No I left the decays alone i just 0'd out the erichment tables for 86* and up
get the tune correct and it will start fine.
Cranking VE, Afterstart Enrichment, Cranking timing, OLFA, Idle Airflow tables, IAC tables
you cant except a car with any mods to Just fire right up with any of these tables being set to stock values
setups particularly, need reasonable idea of the air temp
(prime factor in the gas-law mass calculation). Hotter
IAT reading than real, gives you low air mass thus low fuel
shot, so fights the startup enrichment "choke" while
simultaneously pulling timing. Neither helps the motor to
catch.
