Oil pressure signal...does it go into the pcm????
In order to get my 98 vette cluster to report the oil pressure signal I believe it needs to come from the pcm in the serial data wire because there is no wires designated for it. Am I correct at this assumption???
My problem is that I am running a 98 f-body computer/engine. I know the camaro has a 2 pin oil pressure plug and the corvette has a 3 pin. The camaro pcm does not have an input for the oil pressure signal which leads me to believe this heads straight into the gauges.
How can I get my camaro oil pressure signal into the serial data wire coming out of the pcm???
HELP!!!!
thanks for anything yall can come up with, I appreciate it!!
HELP!!!!
F-Body's report oil pressure right from the sensor... not sure what input the PCM uses though... you'll need the PCM reflashed w/the vette code at minimum I believe to get the signal out
If I could just get a vette sensor and reflash the pcm that would take care of it
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
