EFI Live guys inside please!
Old Jul 17, 2005 | 12:23 PM
kick_*ss's Avatar
Something that probably should be also noted is that there is an EFI University for those that want hands on training. Times and Classes are also up on efi's site.
http://www.efilive.com/forum/viewfor...683b5f0f528395
BTW: I am ( was ) also someone that had ZERO knowledge about tuning. After using LS1edit and getting my cam'ed car running ok, then using EFI its running great. Also posting your comments and suggestions up to EFI they do respond quickly whether they can do something or not.
Old Jul 17, 2005 | 12:26 PM
SmaknaSS's Avatar
Originally Posted by Wet 1
I just receive my copy of EFI LIVE. After doing some reading (okay, the first 85 pages on the Scan tool) I'm trying to get going... Lets just say I don't have have many positive things to say right now!!!
Since there appears to be nothing but electronic tech support (WTF???), would any of you mind sending me your phone # so I can contact you with basic questions? If you don't mind lending a hand, please send me a PM with your contact info.
Thank you SO much!!!
I just got my Flashscan less than a week ago, I was having problem at first too and was feeling the same way you are,but be paitient and read up! I find it's getting alot easer to understand now, I'm starting to love this tuning tool. and the black box feature is real bad ***.
Old Jul 18, 2005 | 06:48 AM
Wet 1's Avatar
Originally Posted by TAQuickness
Wet - pm me your email address. I too will be installing an LC-1 in the next week. I have all ready created my PID. Will be easiest for me to email you the file.
To answer your question though, no, you can't use the LM-1 PID.
Okay, the LC-1 is installed and seems to be functional (no error codes at least). I left my factory NB02 sensors in place since I've heard of some issues with the PCM reading the simulated WB02 signals and I didn't like the idea of splicing into the factory wiring either. Since the rear bungs were not used (C5), I used that location and did a stand alone install.
I installed the LC-1 PID file you sent me (THANKS AGAIN!!!). The LC-1 PID now shows up at the end of the available wideband PID's on the list with the factor EFILive installed PID's. One problem though, it has a cross though it (like all the other unsupported PID's) and when I try to select the PID it gives me a warning message that this in not a valid PID.
What do I need to do to make this PID accessible? Any ideas? I guess I really should take this over to EFI's site, but I see many of the same names are here!
Old Jul 18, 2005 | 06:51 AM
Wet 1's Avatar
Once I was able to get it running I found the basics very straight forward, but as I read some of the more advanced stuff here on the forums I see there is A LOT to be learned! And yes, the black box is sooooo nice!
Old Jul 18, 2005 | 07:01 AM
ace68's Avatar
Wet1 did you get your LC-1 working? Also, you have to put that before the cats or it will give you a false reading.
Old Jul 18, 2005 | 07:13 AM
Wet 1's Avatar
I believe it's working (no error codes and the sensor is calibrated and hot). I just can figure out how to access the LC-1 PID in Live.
BTW, no cats here... only the spotted type and they stay in the house.
Old Jul 18, 2005 | 07:14 AM
ace68's Avatar
you have to click on validate pid and then it should be acessable.
Old Jul 18, 2005 | 07:17 AM
ace68's Avatar
does you pid tex look like this?
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
# See sae_generic.txt for more information on the *UNITS section
*UNITS
#Code System Abbr Description
# Add slot definitions here
# See sae_generic.txt for more information on "SLOT" formats
#Units Low High Fmt Expression
*CLC-00-001
V 0.0 5.00 .1 "{EXT.AD1}"
AFR 10.0 18.0 .2 "({EXT.AD1}*3)+7.35"
*CLC-00-002
factor 0.0 2.0 .1 "{CALC.AFR_LC11}/{GM.AFR}"
*CLC-00-003
V 0.0 5.00 .1 "{EXT.AD2}"
AFR 10.0 18.0 .2 "({EXT.AD2}*3)+7.35"
*CLC-00-004
factor 0.0 2.0 .1 "{CALC.AFR_LC12}/{GM.AFR}"
*PRN - Parameter Reference Numbers
# See sae_generic.txt for more information on the *PRN section
#Code PRN SLOT Units System Description
CALC.AFR_LC11 F001 CLC-00-001 "V,AFR" Fuel "Wide Band AFR 1 - LC-1"
CALC.BEN_Lc11 F002 CLC-00-002 factor Fuel "Base Efficiency Numerator 1 - LC-1"
CALC.AFR_LC12 F003 CLC-00-003 "V,AFR" Fuel "Wide Band AFR 2 - LC-1"
CALC.BEN_LC12 F004 CLC-00-004 factor Fuel "Base Efficiency Numerator 2 - LC-1"
 Michael S. Palmer
Old Jul 18, 2005 | 07:44 AM
TAQuickness's Avatar
WET - I got my LC-1 running this weekend and there is a slight difference in the PID Calculation, verified by the guys at EFILive.
From Ace's post, this is the correct formula:
({EXT.AD1}*3)+7.35
({EXT.AD2}*3)+7.35
You will need to update the PID file I sent you.
Also, you need to select the following PID's to get the AFR from the WB into live:
External Analog Voltage n (required)
Wideband AFR n - LC-1 (required)
Commanded Air Fuel Ratio (optional)
Base Efficiency Numerator n - LC-1 (optional)
Where n = 1 or 2 depending on which input you wired into the flashscan box
If you can stand it, wait till Thursday or Friday this week. I'll be posting a pretty thorough step-by-step autotuning procedure on the EFILive forum.
Wet 1's Avatar
Here's the one I used:
# File details
*FILE
# Units
*UNITS
*CLC-00-001
AFR 10.0 18.0 .2
"(({EXT.AD1}-0.5)*3.3418)+7.35"
*CLC-00-002
factor 0.0 2.0 .1
*CLC-00-003
AFR 10.0 18.0 .2
"(({EXT.AD2}-0.5)*3.3418)+7.35"
*CLC-00-004
factor 0.0 2.0 .1
Description
Old Jul 18, 2005 | 08:02 AM
ace68's Avatar
use this section in yours
*CLC-00-001
*CLC-00-002
*CLC-00-003
*CLC-00-004
Old Jul 18, 2005 | 08:03 AM
  #32
ace68's Avatar
did you mod your dashboard for the pid yet?
Old Jul 18, 2005 | 08:23 AM
  #33
Black02SS's Avatar
You need to make sure you select the BEN for the LC1. You can find that under your pid list under calculations. That PID, the LC1 PID itslef and the AD1/AD2 PID. All need to be selected to use the wideband.
Old Jul 18, 2005 | 09:40 AM
  #34
Wet 1's Avatar
No, I'm not sure how to do that yet... still learning the basics.
Old Jul 18, 2005 | 09:42 AM
  #35
Wet 1's Avatar
That's what I needed to know. Again, I'm not sure how to do these things but I'll check the help instructions tonight... unfortunatly I'm not going to have a lot of time to play with this stuff until the weekend.
Old Jul 18, 2005 | 11:08 AM
  #36
That sux. you will be jonesing all week to get your hands back on it.
Old Jul 18, 2005 | 11:42 AM
  #37
Wet 1's Avatar
Real bad!
Old Jul 22, 2005 | 08:51 PM
  #38
Wet 1's Avatar
({EXT.AD1}*3)+7.35
({EXT.AD2}*3)+7.35
Okay guys, I just looked for these items and made the calc correction to the above file using Ace's values (BTW, the EFI help instructions are near useless IMO!). I was not able to find the specific items you guys listed.
What I did find which was similar was under Pid_info under the PID folder (using Win Explorer):
Ext.AD1=None
Calc.AFR_LC11=None
Calc.AFR_LC12=None
Calc.BEN_LC11=None
Calc.BEN_LC12=None
I tried changing these to "=1" and saved the new values. When I opened the Scan tool, the PID for the WB LC-1 was still crossed out (not valid). After closing the scan tool and going back under Pid_info is see the values are now changed back to "=None". BTW, I didn't have anything connected while doing this...
I'm obviously trying to make changes in the wrong place. Could you guys be specific where and how I need to make these changes please?
Old Jul 22, 2005 | 09:00 PM
  #39
Black02SS's Avatar
Give me a sec and I'll get it for you.
Old Jul 22, 2005 | 09:05 PM
  #40
Black02SS's Avatar
Here is the SAE generic file that you will need. Copy this file to here:
C:\Program Files\EFILive\V7\Configuration
Reopen the scanner and it is all setup for you.
