Smoothing VE Table after SD Tuning With FlashScan?
Bill
1) Apply your BEN to the VE table.
2) Smooth a nice square section around the cells that you hit. I use 50%
3) Re-log and re-apply your BEN
4) Smooth by about 25%
5) repeat step 3
6) Now your BEN should be between .98-1.02 I will then hand smooth the entire table. This point is tediious but it does help the bucking on throttle transitions.
7) repeat step 3
8) Do a quick smooth by 15% and repeat till the BEN is between .98-1.02 (Get it as close to 1.00 as you can. The closer the better.
This is the process that I use and it works great. If you want I would have no problem hand smoothing yours to get it close.
5) repeat step 3
7) repeat step 3
Bill
