160 T.stat and handheld programmer question
Old Aug 1, 2005 | 06:10 PM
Jadedst's Avatar
Default 160 T.stat and hand held programmer ques...
Can i just plug in a buddies hand held programmer to get the fans to come on earlier if i get a 160 t.stat or do i need a true tune to get it to work right?
I tried a search but couldnt find my answer.... so before u guys say anythin...
Old Aug 2, 2005 | 10:56 AM
Jadedst's Avatar
anyone?
Old Aug 2, 2005 | 12:53 PM
2001NBMZ28's Avatar
I don't think you can, most hand held programmers only work on one car at a time. I've only had experience with the Predator and HPP3 though.
Old Aug 2, 2005 | 02:01 PM
Jadedst's Avatar
gotcha, ok.
So after doing a lot of reading, if i get the 160 degree tstat, i NEED the tune so i can get the fans to come on earlier right? If i dont get the tune (or manual switch) will the stat still make a difference?
Old Aug 2, 2005 | 03:30 PM
Bill Bowling's Avatar
Talking
Originally Posted by Jadedst
gotcha, ok.
They will not make any difference without adding a switch or changing the PCM values when they come on. That is a real minor change. Maybe you can find someone that can do it for you.
Bill
Old Aug 3, 2005 | 09:23 AM
Jadedst's Avatar
Thank you very much for the reply!
Old Aug 3, 2005 | 09:55 AM
WS6FirebirdTA00's Avatar
it will make a diff if its 30 deg out and you are on the highway lol but no you wanna turn the fan temps down. coolant is only as cool as you make it. with a 160 stat it will be open as soon as the car gets that hot and prob never close. so the coolant will be hot
Old Aug 3, 2005 | 11:39 AM
STREET GOD's Avatar
Default Slp Fan Switch
Slp Makes A Fan Switch For $65.00 Through Ws6 Store That All You Have To Is Hook Up And Turn It On And Off When Needed
