Max allower enrichment
Maybe this time...
What does it mean?
I know it doesn't affect PE; maybe it's a test; maybe it's the limit of the LTFT correction
Who can explain it to me?
Thanks - Stefano
"I'm in the Charlotte area and have HP Tuners, PM me for any kind of tuning help or mod install help"
You are supposed to answer and not to ask
OK bad joke
Edit
Engine cal
Fuel
Max allowed enrichment
Stock is set at 1.13
Vortech set it at 1.39
look at the picture
Looks like nobody knows it anymore - not as bad as many think...
I checked with a WB and I can set the AFR as I want: it only depends on PE vs RPM.
you can put it at 1 or at 2 it doesn't matter.
But for something it is there... why?
You think that the PCM commands an AFR of 13:1?
14.7 / 1.13 = 13.0
Do you see any reason why Vortech sets an higher value? This would make an AFR of 10.6. Unless you are under boost it doesn't really makes sense to go so high.
Unless it's if for some reason PE doesn't work properly... then it would be OK
