airbag light with header install........ i sure wish this was in the sticky!!!!
so i read the sticky for exhaust, and did my header install, pretty much flawless. What i wish was in the sticky, was to make sure you lock your steering wheel!!!!!! i now have an airbag light, with SES light. After doing a search on here, i see that it's the clock spring most likely, because we decided to play wheel of fortune with my steering wheel, while the linkage was out!!
Am i correct in thinking this? is this my problem? anyone have one?
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
More than likely sir, you are correct. Try finding one in a junk yard as they are not cheap at all through the dealer. They are not really hard to replace witht the right tools.
