IAT Sensor
Old Sep 21, 2005 | 06:19 AM
PaulFLS6's Avatar
Default IAT Sensor
I have installed a LS6 into a Cobra replica. I am using the stock PCM and wiring loom.
The only wires I can't find a home for, are for the IAT (intake air temperature) sensor. Do I need to run one, and what effect does it have on the engine. Can I just by-pass it?
Old Sep 21, 2005 | 08:14 AM
MeentSS02's Avatar
Kleeborp the Moderator™
If you are using a stock PCM, you WILL need an IAT sensor...it is an important part of the calculations for airflow.
Old Sep 21, 2005 | 10:51 AM
PaulFLS6's Avatar
Default IAT Sensor
I have been told it is possible to bypass the sensor using a resistor. I know someone who has run his engine without it, so it would be really useful to try and understand what it is doing exactly.
Does anyone know where I can buy the sensor from?
Old Sep 21, 2005 | 10:53 AM
MeentSS02's Avatar
GM should have one...I personally use an 85mm truck MAF that has an imbedded IAT sensor. What you might also look at is SLPs timing tricker...that is the resistor/IAT thing you are hearing about.
Old Sep 21, 2005 | 11:23 AM
SSpdDmon's Avatar
I thought the LS6 had the IAT sensor in the MAF? Are you running a seperate temp sensor? It should all hook up in the harness I thought....
Old Sep 21, 2005 | 03:36 PM
jimmyblue's Avatar
Moderator
LS6 has a 5-wire MAF connector and two of those are the
in-throat IAT sensor. "Z06" MAF or truck MAF and you
are good to go.
Old Sep 22, 2005 | 03:56 AM
PaulFLS6's Avatar
I should have said I am using a mechanical throttle (LS1) on my LS6. I think this may be why I can't find a home for the IAT sensor. What do you think?
Old Sep 22, 2005 | 04:22 AM
PaulFLS6's Avatar
I think I am going to fit an IAT sensor in the air intake tube. Does anyone have a good source for GM parts, as I will need to get it shipped to the UK, and I don't think this is a part that I can source over here.
Old Sep 22, 2005 | 04:57 AM
stevemilz's Avatar
http://installuniversity.com/install...sity/index.htm
My Camaro was running like garbage, it was braking up (spark knock). I scanned it no codes, just for fun I unplugged the IAT it started to run smoother. I drove it for 3 days like that it ran alot better, Then I got a check engine light. I put a resister on and cleared the code. What I dont understand is when you put the resister is it adds timing, but for some reason if pretty much eliminated my spark knock!? I know it wasnt bad gas cuz Ive been running 93 with octane boost.
Old Sep 22, 2005 | 10:02 AM
MeentSS02's Avatar
A bad IAT will pull timing, but putting the resistor in will NOT add timing...it just won't pull any from the existing tables.
Old Sep 23, 2005 | 09:22 AM
jimmyblue's Avatar
Moderator
Did you look at the MAF and the MAF harness yet? 3 pins or 5?
Old Sep 23, 2005 | 10:48 AM
PaulFLS6's Avatar
No I haven't had a chance . I'll try and investigate further over the weekend. At the moment I am thinking that the resistor will be the simplest solution.
