How bad is KS code hurting performance?
Old Oct 2, 2005 | 04:09 AM
01Lowboy's Avatar
Default How much is bad Knock Sensor code hurting performance?
I just wanna know what the likely performance loss is if u've got a bad knock sensor. Maybe it's just me or the code but i lost 3mph in my 1/4 since this light has come on and i wanna know what kinda power loss i'd suffer from a bad knock sensor
Old Oct 2, 2005 | 08:41 AM
P Mack's Avatar
It pulls 4 degrees of timing across the board if i remember right.
Old Oct 2, 2005 | 10:26 AM
horist's Avatar
also it drops you to the low octane table... it's hurting performance bad... I had a P0327 a while back... fixed it at the track... I lost over 1 second in my ET from the code being set
Old Oct 3, 2005 | 12:31 AM
01Lowboy's Avatar
think i should replace both sensors? or the wiring harness
Old Oct 3, 2005 | 07:20 AM
P Mack's Avatar
Depends, did you recently have the intake manifold off?
Old Oct 3, 2005 | 10:33 AM
01Lowboy's Avatar
yea, did a ls6 swap
Old Oct 3, 2005 | 12:57 PM
P Mack's Avatar
Chances are you pinched the wire under the manifold and it's grounding out on the block. Either that or you unhooked the wire and forgot to plug it back in after the swap. That's what I did (yeah I know it doesn't have to come off, i was just unhooking everything). Anyway, i'm guessing it's the wire and not the knock sensors.
Old Oct 3, 2005 | 01:47 PM
horist's Avatar
^^^^ ditto... search for posts in this section by me (horist) w/keyword P0327
I pinched the wire when I did my LS6 intake upgrade
Old Oct 3, 2005 | 10:14 PM
01Lowboy's Avatar
alright, thank man i appreciate it
