Adding PE = No Effect
But ya, it seems like there is a limit at that RPM.
What am I missing?
Also what is the value you have in the ve table at wot above 4k rpms?
the fuel air multiplier and reference that, to the various
fuel tables (PE, OLFA, COT, adders in play) and see who
is in charge. It might help, if values are the same, to put
a little flag on them (for example instead of everybody
being 1.200, make OLFA be 1.201 and PE be 1.203, etc.).
It might also be interesting to look at the airflow and
CylAir readings as you cross 4000, see if there is any
discontinuity / jump / drop in the value as you run up.
If the SD and MAF are fairly different you might see
something not-smooth at the final transition?
If COT commands 11.5 and PE commands 12.5, COT will override and the AFR will be 11.5. If you bump PE to 12.0, it will still be 11.5. COT shows up as part of commanded AFR, so you can at least tell.
John.
I never touched the OLFA table, how does it work??
into open loop. Any time you see a commanded
fuel air multiplier <> 1.000 you are open loop. In
open loop the PCM will pick the fattest of the
currently enabled enrichments (PE, OLFA, COT,
whatever).
Anyway, when you meet the conditions to enable
PE, you enter open loop and then pick the chubby
option. If OLFA(MAP,ECT) is greater than the PE(RPM)
then you get the OLFA value.
This really gives you one and one-half degrees of
freedom in tuning WOT. A MAP based enrichment,
and an RPM based one. But the "pick fatter" limits
what you can do, some.
You might find it better to tune as far as possible
with the OLFA table, and then use PE just to tweak
the top end (where the injector table, etc. may fail
to properly model plumbing flow-pressure drop, etc.).
PE gets all the attention but OLFA and the MAP
relation to required enrichment I think is more to
the point.
loop. It doesn't have any say about how you get
there, just what happens once you are.
PE mode (MAP, TPS) is the only convenient and
consistent way I know of, to get into open loop
in normal operation. Point is, that once in PE mode
you might prefer to control the fueling on a mostly
MAP basis (OLFA) and use the PE table for RPM-
specific needs.
Or not.
