G5X3 install, now code PO300 misfire detected....
Old 10-15-2005, 05:47 PM
wavrdr's Avatar
Default G5X3 install, now code PO300 misfire detected....
Can anyone give me some advice on tuning this out. I have an HPTuners tune in the car but am unfortunately getting code p0300(engine misfire detected...)
I know this is extemely vague, but I'm new to the tunig thing and this tune is from another member with the exact car(year, mods etc..)
The car is an 02' ZO6.
TIA
Old 10-15-2005, 05:54 PM
TAQuickness's Avatar
you need to do a case relearn. you may also need to desensistize (sp) the knock sensors at idle
Old 10-15-2005, 06:29 PM
LS1TECH Sponsor
foff667's Avatar
I would say delete the code &/or desensitize the misfire tables slightly at low rpms. This is pretty normal for large cams...not sure if desensitizing the knock sensors will do anything for you though.
Old 10-16-2005, 02:24 AM
luv2spd's Avatar
Set the idle and low rpm tables all to 32000.
Old 10-16-2005, 07:33 AM
wavrdr's Avatar
In which table do I do this?
Again guys I'm new to this, the HP actually belongs to my buddy who is out of town, so I'm definitley in the dark...
Old 10-16-2005, 09:13 AM
LS1TECH Sponsor
foff667's Avatar
misfire
Old 10-16-2005, 04:54 PM
Gman2002Z06's Avatar
What are your mods...I'm running the G5X3, LT with cats, Vara-Ram CAI and get no misfire codes...Let me know if you would like me to e-mail you an Excel file with all the important parameters...You could then compare and modify as you see fit...
Also, make sure that all your plug wires are snug and in good shape, one plug wire loose or going bad will through the 0300 code...
Peace...Gman
Old 10-16-2005, 06:48 PM
wavrdr's Avatar
Mods are as follows:
Vararam
Halltech air bridge
LG LT's(no cats)
GHL Magnum plus catback
160* thermo
G5X3 114
My e-mail is stngetr@comcast.net
I do appreciate the help. I was able to cure the misfire code but if anyone has any tunes that I can compare to that would great....
Alan
Old 10-16-2005, 07:03 PM
I e-mailed the .bin file and an Excel file to you...Our mods are very similiar, except for the cat back (I'm still using the stock Ti's) and I have the Hi Flow Cats...
Keep me posted as to how any of the info works for you...
Peace...Gman
Old 10-16-2005, 07:11 PM
wavrdr's Avatar
Thanks bro, I'll compare the two and possibly make some changes...
Thanks for the help you guys!
