"displacement" do anything??
Old Nov 11, 2005 | 05:51 AM
Dave F's Avatar
Default "displacement" do anything??
I use LS1 edit and LS2 edit. In the engine/fuel pages, there is a tab for cylinder displacement. Does changing this number actually do anything, or is it just for reference???
I assumed this number might "scale" the VE tables, or something similar, but now I'm not so sure. The Stock tune in my 2005 LS2 has the wrong displacement listed, so I'm starting to think it is just there for reference.
Anybody know?
**here's what I'm talking about. This is the OEM tune from my 2005 LS2 Vette (not the race car)
Old Nov 11, 2005 | 06:32 AM
TAQuickness's Avatar
I'm not sure exactly what the PCM does with it, but my psychic horse power meter felt a differnce when I set mine to the appropiate displacement.
When I changed it in EFILive, it did rescale my VE table.
Old Nov 11, 2005 | 07:10 AM
Dave F's Avatar
it doesn't seem to rescale my primary VE, but maybe there is a "multiplyer" somewhere in the system. Unfortunately, I can't find any logging software for the new CAN enabled cars, so I can't play with the fun stuff yet.
Old Nov 11, 2005 | 08:44 AM
Billiumss's Avatar
In HP Tuners, by changing that number it will rescale your VE table.
Old Nov 11, 2005 | 12:22 PM
Bink's Avatar
TAQuickness- I think your "psychic horse power meter" should be included in your sig.
Old Nov 11, 2005 | 12:28 PM
HumpinSS's Avatar
it should rescale the ve table if you look in the "ve cracked" thread you will see where that number is referenced for calculations.
Old Nov 12, 2005 | 12:03 AM
Just a fancy way of saying i have vinyl racing stripes
Old Nov 12, 2005 | 08:48 AM
Blk02Ls1A4's Avatar
.708 x 8 = 5.664 L
That tells the pcm the volume of each cylinder. If you were to add a 4" crank then your cyl volume would change, making it important to change this number to reflect the correct volume. If you were to increase your cyl volume and not change this number your calibrations that use this would be off resulting in less power.
Old Nov 12, 2005 | 10:05 AM
RedHardSupra's Avatar
it's a constant multiplier for just about every calculation in there. so while not exactly crucial to have it set up (it will just rescale the VE table by a linear factor) it is easy enough (bore^2*stroke*PI, then convert to liters) to do it, and the benefit of is is that you get to have a meaningful VE table (aka 100% means you're filling your cylinder with the exact amount of air the cylinder displaces). just do it, it's simple math.
Old Nov 12, 2005 | 10:23 AM
slow's Avatar
Does it really rescale the VE values in the calibration, or just the displayed values in the the software?
Ryan
Old Nov 12, 2005 | 10:26 AM
no, it doesn't rescale it for you, what i meant was if you change the displacement and scan fuel trims again, your VE will end up consistently multiplied by the same factor that displacement got muliplied by.
