Car wont turn over?!?!?!
Dave
2. can you hear the fuel pump engage?
3. can you crank the motor by hand?
4. Can you jump the starter? Does it then turn the engine over?
I believe there's a relationship between the BCM and the starter... is VATS enabled in the PCM?
this could be a million things since it's a complete wiring harness, PCM, engine, trans swap.... we need some more details on what diagnostics you've already done...
Thanks, Dave
Do i need it or can i just cross some wiring.I found the wiring on the sticky for a4 to m6 but i dont have a purple white striped wire. Anyon else do a swap into a 93-97 v6.
Dave
