what is SD tuning?
A slightly biased answer based on my point of view, but a factual representation of the process.
Maf = good
Ryan
I personally prefer speed Density... it's easy to tune and eliminates a restriction (If you choose to remove the MAF... especially useful if you have a FAST 90or LS2 intake manifold ... since they don't make a 90mm MAF... it eliminates a restriction)
seems some prefer to run on a MAF others prefer SD ... SD is really a failover mode in our cars..
One thing that's kinda funny ... alot of mustang guys (5.0 mustangs) do anything they can to switch over to a good MAF setup .... whereas seems late model GMs are the reverse.... heh
once you have an SD tune done, then you can also calibrate your MAF if you choose (a properly calibrated MAF will make idle tuning and regular tuning considerably easier ... or you could stay SD and it's still pretty easy)
I do like tuning a ford vehicle correctly in about 30 minutes with a maf. 30 points and your done.
Ryan
Bill
I'd call you tuner and tell him someone on the internet raised the
flag on him
My cam is slightly larger than Bill's and I'm running OLSD no problem.
1. MAF and VE is used under 4000rpm.
2. MAF is a restriction, depending on size, to the intake so limits HP. Note: not a concern on mildly modied cars. Note: if you port you maf you will need to re-calibrate the PCM.
3. SD, you can do this Wideband or NarrowBand! You can also turn of LTFT and limit close loop mode. The drag racers uses this method as they can command the AFR to 13/1.
MAF is good for emisions and fuel, SD is the way to go for racing. SD narrowband is in between.
IF you still have a MAF you still need the VE for Part throttle.
basically anything under 4000 rpms and changing throttle conditions is VE. your MAF is only used in Steady State conditions....which is defined under airflow-dynamic airflow...
so if you dont tune your VE, you have tip in knock and crappy throttle response.
You dont need the MAF at all...you car relys on your IAT...which means that cars with IAT in the MAF need to buy a seperate IAT if they want to get rid of MAF totally...
I have been in SD for almost 8 months now.....
there has been no changes to my VE LTFT's in that time..climate here changes a lot
was 70*F outside 3 days ago...very next day it was 20*F!!! no change in trims as I was working on a writeup for tuning Open Loop Table..still in teh works....trying to get a definate way to do it..have tried 3 different things.....geting a lot closer now...think I have it...just need to do an actual writeup now...
many tuners put back on teh maf after doing VE tuning..and forget to recalibrate the MAF to match the VE that they just tuned....LOL
and to the comment above that says the MAF pulls harder....
Try My car....or any SD tune that I have done....
for the mods on the car...pulls way harder than with MAF on
no problem
the cool thing with nitrous is that its usually fuel controlled by the jets...
so you just tune VE like normal(with a wideband)
and then you can use a controller to take out timing for spray...or you can do it in the IAT correction table using 284* and wire a resistor up to the IAT with a relay switch based on your Nitrous window switch...and you can do it without an extra controller
