timing at shift points
Old Nov 27, 2005 | 10:36 AM
zrater's Avatar
Default timing at shift points
timing is dropping to -10 at shft points and when i first dump it to
the floor it will drop to -8 to -10 is that right, and im running 19
to 26 degrees timing thru the hole rpm range with about 2- 3 kr. thanks
Old Nov 27, 2005 | 11:04 AM
SS LS1's Avatar
Sounds like Tourque Management is kicking in. What all did you tune with your HP Tuners? Did you try to disable Torque Management with the software? Maybe a paramter did not get turned off?
Old Nov 27, 2005 | 11:30 AM
zrater's Avatar
just fans and timing to get rid of kr.
Old Nov 29, 2005 | 01:17 PM
zrater's Avatar
anyone..............
Old Nov 29, 2005 | 01:20 PM
12secSS's Avatar
Yup, engine torque management is kicking in. You can either reduce it or eliminate it, your choice.
Old Nov 29, 2005 | 01:28 PM
foff667's Avatar
LS1TECH Sponsor
Old Nov 29, 2005 | 05:20 PM
zrater's Avatar
THANKS VERY MUCH GUYS.....................
