Will LS1 Edit work with Ed Wright tuning?
Old Jan 29, 2002 | 06:35 PM
Reckless's Avatar
Super Moderator
Default Will LS1 Edit work with Ed Wright tuning?
I sure hope so! Anyone know?
Old Jan 29, 2002 | 07:19 PM
BluVette's Avatar
Default Re: Will LS1 Edit work with Ed Wright tuning?
Will LS1 Edit work after the TTS Powerloader install?
Can you write back over LS1 Edit with the TTS Powerloader?
How many programs can you save and reload using LS1 Edit? Like a drag racing program, autocross
program and a regular daily driver program.
Old Jan 29, 2002 | 07:36 PM
cablebandit's Avatar
carputing told me a pcm peogrammed by Ed more than 3 months ago would most likely work
Old Jan 30, 2002 | 09:47 AM
SSBoy's Avatar
ttt (i would like to hear this as well)
Old Jan 30, 2002 | 09:44 PM
Chris Jones's Avatar
Someone once wrote that Ed and others "encrypt" the changes they make so no one else can alter the program. I don't know technically how it's possible, sounds like some <img src="graemlins/gr_bs.gif" border="0" alt="[bullshit]" /> . But I'm no expert, yet!
Old Jan 31, 2002 | 12:44 AM
Ryan K's Avatar
Pathological Modifier
Well, it depends on how long ago you had it tuned. If it was longer than about 3 months ago, you should be safe. I was safe, and found an unscrambled tune. And yes it is posible to scramble the code enough to prevent reading it. But you can have the car's PCM flashed back to stock and then work from there. This is the MOST desireable method.
Ryan
BTW the 98 version works fantastic! <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Jan 31, 2002 | 06:11 PM
Palm Beach Z's Avatar
I ordered the LS1 Edit, then found out that the PCM was locked by Ed Wright. <img src="graemlins/gr_bs.gif" border="0" alt="[bullshit]" /> Dave at Carputing said I could go back to stock programming and go from there. I can't do that!!! I have all kinds of codes, EGR, AIR, etc... deleted. Can I use LS1 Edit to delete all these codes? <img src="gr_eek2.gif" border="0">
Old Jan 31, 2002 | 06:27 PM
Ryan K's Avatar
YES you can delete any code with the LS1 edit
Ryan
Old Feb 1, 2002 | 04:14 PM
Quick355's Avatar
Will LS1 Edit reload the stock programming? I have Z Industries programming and want to start from stock programming.
-Allen
