shift points with LS1 EDIT
Won't my shift points be thrown off at the track with bigger tires, since my pcm will be programmed to my street tire size? <img src="images/icons/confused.gif" border="0">
Steve
I am going to change my shift points with Brian from BV Performance in the next couple of weeks.
I plan to run taller tires at some point and I would think that 28x10x15 Hoosier slicks would throw off the MPH thang right?
That being the case, if I want both of my shift points at 6600, what mph would that be at with 4.10's?
a 26" tire hits 6600rpms at 41mph on the 1-2 and 77mph on the 2-3.
a 28" tire hits 6600rpms at 44mph on the 1-2 and 83mph on the 2-3.
So if you use 41mph as your 1-2 shift point, but use a 28" tire, the car will short shift at 6100rpms.
If you use 44mph as your 1-2 shift for 28" tires, but decide to go back to 26" tires you will shift at 7200 rpm. <img src="gr_eek2.gif" border="0">
I think thats right? <img src="images/icons/confused.gif" border="0">
later,
Steve
Ryan "hope that made sence" K.
<img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
<strong>Well guys it does shift off of MPH. BUT remember it calulates MPH from the Drive shaft speed.</strong><hr></blockquote>
Yea Ryan. You understand correctly. You could also say, it shifts off indicated speed, not actual speed as the car has no real clue how fast it's going, only how fast the driveshaft is turning.
Ira
How do you figure out the indicated mph that would equate to 6600 rpms? Or should I just tell my tuner that want to shift at 6600rpms and let him figure it out. <img src="gr_grin.gif" border="0">
thanks,
Steve
<strong>
Ira</strong><hr></blockquote>
Just as a point of interest, C5s works a little differently. The VSS pickup is on the ring gear and what the PCM sees is really axle rotation rate not driveshaft rotation rate. Where is the F-body VSS signal supplied?
<strong>How do you figure out the indicated mph that would equate to 6600 rpms?</strong><hr></blockquote>
There is a setting for tire diameter somewhere I think. The formula would be
Driveshat Speed/finalDrive*tireDiameter(in)*PI/12/5280*60
Or
Driveshat Speed/finalDrive*tireDiameter(in)/336
Where Driveshat Speed = Engine RPM/Trans gear ratio
[ February 15, 2002: Message edited by: spiesscj ]</p>
But, remember the Torque converter has slip, so that equation doesn't account for TCC slip speed. Every car is going to be different so, its more of a trial and error setting.
Ryan <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
What would I plug into LS1 Edit to have 6600/6600 shift points with a 4.10 gear out back and 26" tall tires.
I for my first try, I would go for:
1-2 @ 35 MPH
2-3 @ 66-67 MPH
3-4 @ 110 MPH then at the track leave it in (D)
Thats where I would start.
Ryan K <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Ryan <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> [/QB][/QUOTE]
True true. You can use the standard shift Pt Vs RPM tables to get pretty close though. It's actually fun to see cars make more power and creat higher stalls so that you have to go back into the program and adjust shift points for it!!!
<img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
[ February 15, 2002: Message edited by: Mr Cowl Hood ]</p>
