Torque Management/LS1 Edit question
Under the Engine section of LS1Edit in the ignition table there are two TCS tables. The second table is all zeros, anyone know why?
Also if I lower the values in the first table will that affect the traction control or torque management between shifts?
BTW, my car is a 99 C5 A4.
Re: Torque Management/LS1 Edit question
hmm in mine file I have the first table as all zeros ( the TCS Retard vs. RPM). The second table (2nd TCS Retard vs RPM) has numbers gonig sequentially up from 17 through 36 in the 400 rpm increments starting at 400 and ending at 8000rpm.
Maybe because torque management was taken off my car it has zero values in the 1 table .
What are your values in the first table?
