CAGS and LS1 Edit
Old Mar 11, 2002 | 05:57 PM
chasgiv3's Avatar
Default Re: CAGS and LS1 Edit
You have your choice of what MPH it comes on at and when it is disabled. I looks like you can do what you stated. Not sure if there are any limits on MPH within the edditable fields
Old Mar 11, 2002 | 06:05 PM
Team ZR-1's Avatar
Since I have to use 4th gear at the drag strip I changed the cags light to some on at a speed I would want to shift into 4th gear.
Of course I have the 1st/4h gear switch disconnected so the light will only come on when it reaches that speed.
[quote]Originally posted by Freak:
<strong>Hey guys, I'll be gettin LS1 Edit soon and was wondering something about the CAGS, can it be set to come on at above around 75-80? and stay on till about 105-110?
My thinkin is to set this up so it is engaged when you are in 3rd, so it woudl be impossible to shift into 2nd instead of 4th. Sorta liek the Drag Cags, but automatic instead of with a switch....
anyone know if this coudl be done?</strong><hr></blockquote>
Old Mar 12, 2002 | 12:06 AM
Freak's Avatar
Default CAGS and LS1 Edit
Old Mar 12, 2002 | 05:22 PM
Rock's Avatar
I was told CAGS will only work from 1st gear, and only first gear by the people at LS1 Edit. I hope they, and I am wrong, automatic drag cags would rock.
(I bent a few valves in my day.. I'll never hit fourth the same again <img src="gr_sad.gif" border="0"> )
<img src="gr_stretch.gif" border="0">
Old Mar 12, 2002 | 09:03 PM
John B's Avatar
Moderator
The easy fix is to raise the temperature to activate it to something silly like 250°.
Old Mar 13, 2002 | 05:35 PM
Freak's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by John B:
<strong>The easy fix is to raise the temperature to activate it to something silly like 250°.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Huh? Im not trying to do the skip shift eliminator... just wanna try to do an auto drag cags...
thanks for the help guys
Troy
Old Jul 1, 2002 | 07:57 PM
wizkid's Avatar
Install Director
Would making the TPS 0 to deactivate work too you reckon?
Eric
Old Jul 1, 2002 | 11:17 PM
Ben99Z28's Avatar
here's how i disable mine:
speed enable: 250mph, disable: 250mph <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
enable temp: 298
%TPS to disable: 1
I would assume the CAGS will be disable permanently as long as the above condition weren't met, it seems to take care of the skipshift light as well <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
