My LS1 Edit trials:
Old Mar 18, 2002 | 08:49 AM
SAM98WS6's Avatar
Default My LS1 Edit trials:
Added ARE stage II heads, T1 cam, FLP w/cats, SLP MAF
Car runs good on stock tuning
Used LS1 Edit to do the basics:
Gear ratio, Rev Limit, Fan on/off, CAGs disable, Remove O2 codes, Adjust Idle speed, Raise Torque Management etc
Atapped and found:
LTrims where in the +7-9% range the entire run
Timing was down to 25 degrees at some points so I adjusted to 30 based on MAF rate
Zero KR everywhere except 2 at ~4500 so I desensitized the Knock Sensors 25%.
O2s were in the .92-.93 range throughout the run.
Going to do some more atapping and lean the car out a little. Any tips on how you experts would do it? I love LS1 edit.
Old Mar 18, 2002 | 09:10 AM
cablebandit's Avatar
Default Re: My LS1 Edit trials:
how did you desensitize the knock sensors by 25% i dont understand that part of ls1edit. I would reduce timing around 4500 before desensitizing knock sensor. I assume you made sure it was false knock. Want you to run fast for a loooong time <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 18, 2002 | 03:01 PM
Potent98's Avatar
cablebandit
How do you MAKE sure it's not false knock?
Old Mar 18, 2002 | 04:51 PM
run 100 octane and see if it goes away.b
Old Mar 18, 2002 | 09:29 PM
Mr Cowl Hood's Avatar
Were your LTRIMS measured right after you downloaded the tune or did you drive it a while before that?
Also, did you see these values (+7-9%) on the WOT run? That would be strange. They should go to 0 at WOT. STRIMS should too.
Old Mar 18, 2002 | 11:43 PM
NicD's Avatar
7 Second Club
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mr Cowl Hood:
<strong>Also, did you see these values (+7-9%) on the WOT run? That would be strange. They should go to 0 at WOT. STRIMS should too.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe the LTRIMS lock to whatever they were last at before WOT during WOT. I don't believe they just go to 0.
Old Mar 19, 2002 | 11:11 AM
SAM98WS6's Avatar
I am sure it is false knock.
I made the Atap run at least 15 miles of driving after the last download.
Ltrims were in the +7-9% throughout the WOT run.
There was a thread about modifying one of the Knock tables by .75. Dont know if this worked yet but I will let you know.
Should the Ltrims be closer to zero??
Old Mar 19, 2002 | 09:04 PM
John B's Avatar
Moderator
SAM98WS6 </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Timing was down to 25 degrees at some points so I adjusted to 30 based on MAF rate</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">what portion of the timing table did you change to get 30° and based on what MAF rate?
Old Mar 20, 2002 | 01:58 PM
LS1JM's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nic00Z28M6:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Mr Cowl Hood:
<strong>Also, did you see these values (+7-9%) on the WOT run? That would be strange. They should go to 0 at WOT. STRIMS should too.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe the LTRIMS lock to whatever they were last at before WOT during WOT. I don't believe they just go to 0.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">MY LTRIMS lock at whatever they were just before I got to WOT in fuel cell 22. This is using the TECH II. Joe..
<small>[ March 20, 2002, 02:25 PM: Message edited by: LS1JM ]</small>
