Uneven ltrims
Thanks <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
I will try to move the bank1 02 sensor to the 2nd bank, I have rear 02’s but they are not same are they? <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Any other idea’s on what to look for? Any one had a problem like this before?
Thanks for the tips guys <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
A mis-fire condition on Bank 1 could also cause this condition. (cyl miss-fires so the uncombusted air reaches the O2 - commanding more fuel to that bank)
Check your "misfire current" parameter for you cylinders and see what they read. (This parameter reads # of misses per 200 revolutions than resets: Look for 1 that may be up in the 60-70 range at off-idle.
Thanks <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
<small>[ April 04, 2002, 08:18 PM: Message edited by: dissonance ]</small>
-Exhaust leaks will absolutely screw up stuff. Any leak before the 02's will make all readings useless IMO.
-Lazy O2's will make the car run rich. 02 can be lazy from being coated with junk.
Please any other ideas before I blow another $117 on an o2 sensor
Maybe try cleaning your 02's with contact cleaner?
they can be found here
http://208.202.224.10/autotap
links right to them
http://208.202.224.10/autotap/ltrims.atl
http://208.202.224.10/autotap/ltrims.csv
i have both the autotap and excel output's
please take a look at these <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
