Need Help!!!!!!!
Old Dec 21, 2005 | 08:51 AM
SgtB's Avatar
Horist..good find....I will check the resistor tonight and see if that is the problem.It sure sounds like the problem
Old Dec 21, 2005 | 09:28 AM
BADSZ28's Avatar
Good Luck with it. Sorry you had to tow it.
Old Dec 21, 2005 | 09:39 AM
SgtB's Avatar
Hopefully it is that resistor...I need to get this car up and running...I don't need my wife with her lead foot driving a Suburban with a big block
Old Dec 21, 2005 | 10:25 AM
Okie5.3's Avatar
Originally Posted by SgtB
The cam positioning sensor???? How would that go bad?
not sure why it would, there fairly cheap, might be worth a try. had a buddy that was having the same problem you are describing....vehicle would start run for a couple seconds, die. he would start it again...run for a couple seconds and die. this happened all of a sudden. he drove into town, turned it off to run into a store and when he came out it wouldn't start. i was thinking fuel related, but it turned out to be the cam positioning sensor.
Old Dec 21, 2005 | 11:07 AM
SgtB's Avatar
interesting..I will keep that in mind too
Old Dec 21, 2005 | 11:51 AM
WS6FirebirdTA00's Avatar
ive seen the same problem with a bad ignition switch or messed up ignition wires
Old Dec 21, 2005 | 01:39 PM
SgtB's Avatar
WTF
I really hate this car...
I never liked this car ....oh well
Old Dec 21, 2005 | 07:45 PM
SgtB's Avatar
Thanks Horist!!
It is the fuel pump resistor..I am picking up a new one in the morning
Old Dec 21, 2005 | 08:50 PM
Okie5.3's Avatar
glad i was wrong...that is much easier to replace than the CMP sensor.
Old Dec 21, 2005 | 09:38 PM
horist's Avatar
may wanna check with casper electronics too ... they make a bypass kit that's pretty plug in play...
Old Dec 22, 2005 | 07:10 AM
SgtB's Avatar
I am going to get a replacement today
