Best Shift Points...
Car is '98 Trans Am, A4, 80,000 miles
Mods are-
direct-flo lid, slp smooth bellow, stock exhaust manifolds with ORY into Magnaflow Catback, with QTP Electric Cutout, B&M 3000 stall converter & tranny cooler.
I've had no kind of tuning, there's really no where local to get it done...
Have thought of a mail-order tune here lately, might have to look into it...
I have a Hypertech PPIII, and it adjusts shift points, shift firmness, shift rpms and by mph, rev limiter, fan control, recalibrating speedo and all.....plus it has the Power Programming which I took off because it made the car run so lean...
I just got the converter in about a week ago, and I have kind of a hesitation between shifts, it'll just hang around 6L for a sec or 2 before it shifts into the next gear, like it's not used to getting there that fast...
Does anyone have any ideas on what I should raise the shift firmness to, and what would be some good shift points(by rpms) in all gears, and what my rev limiter should be too...
Any help is appreciated, thanks.
WOT shift points can be determed by powerband on the dyno
Part throttle shifts are best determined based on the vehicle acceleration rate.
Ryan
Converter lets the RPM "stretch ahead" some, maybe
enough to hit the limiter.
Depending on where in Virginia, maybe some of the
North Carolina folks might be able to help you. Try
your regional forum with a call-out for HPTuners
people, '98-Fbody licensed.
Haven't seen too many people with LS1s running the
B&M converters. How do you like it, how strong is
the lockup clutch (slip on uphill grades or stay locked,
etc.)?
And do you mean bring the mph down before it shifts.? or go up some.? I misread it..
