how to lean/richen and raise timing with Edit???
Old Apr 10, 2002 | 08:32 PM
tang_ta's Avatar
Default how to lean/richen and raise timing with Edit???
I was rich now I might be lean..I'll find out, but my timing is at 18 degrees average on a run. How can I raise that and richen/lean it out if I have to?
James
Old Apr 11, 2002 | 11:50 AM
MIGHTYMOUSE's Avatar
Default Re: how to lean/richen and raise timing with Edit???
check the instruction manual on the carputing homepage my man.
Old Apr 12, 2002 | 12:50 AM
ChrisB's Avatar
Yep, it's included in the instructions - I would suggest giving them a good reading. Timing will be altered in the hi and low octane timing table.
You can not change part throttle air/fuel, though you can change your l-trims (using the MAF transfer function, etc.) - at WOT use the PE vs RPM table to change your a/f ratio.
Do a little reading and understand what you are doing before you make changes though.
Chris
