Anyone using an FJO WB Setup
Old Apr 16, 2002 | 07:43 PM
Phate's Avatar
Default Anyone using an FJO WB Setup
Guys,
I ordered my WB system from FJO and I was wondering if anyone had any experience using this? What did you think if it?
Thanks,
Scott
Old Apr 16, 2002 | 11:41 PM
Futral's Avatar
Default Re: Anyone using an FJO WB Setup
Which system setup(display,etc..)did you get?Did you get it from FJO or from a dealer?Looking at the stuff now.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Apr 17, 2002 | 01:51 AM
Phate's Avatar
I got the kit that had everything in it...the one with the nice display, the logging kit, the rpm input, the controller, the install kit, and the WB o2 sensor.
I'll let you know what it looks like when I get it...I ordered it from a dealer, Alamo Motorsports
Scott
Old Apr 17, 2002 | 07:54 PM
nevrenuf's Avatar
I've got the full system installed permanently in my Vette. O2 sensor is welded into the header collector, dash mounted display, and a PC/PDA interface to support data collection during dyno runs, nitrous tuning, etc. which provides A/F ratio, Throttle Position, and RPM all on the same graph....
Old Apr 18, 2002 | 11:36 AM
Phate's Avatar
Thanks for the info <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
How has this worked for you for tuning? Do you feel that you have pickep up power from using it to tune?
Thanks,
Scott
Old Apr 18, 2002 | 07:02 PM
Phate's Avatar
Why would you need to run two sensors? Can't you just run one sensor in the Y-pipe? or does it have to be closer to the manifold?
I'm going to be installing this sucker tomorrow, so it would help ma a lot to know.
Thanks,
Scott
Old Apr 18, 2002 | 08:22 PM
red ws6 99's Avatar
Well I would think the y-pipe would be to far back, but should work just response time will be slower. Also left and right banks will run slightly different afr, probably passenger side bank will be leaner compared to driver side. This is based on the stock fuel rails and dampener, etc. On my setup (low boost/power) I dought that the two banks will be that different.
You are running the Incon TT setup right? At this point I still dont have the y-pipe from Incon, supposed to get that shipped next week along with the rest of the stuff. It may work ok back in the y-pipe.
I also plan on having at least two egt sensors and later one for each cylinder, especially since the manifolds already are drilled for them. So the temperatures and the one wideband sensor should be good enough to tune with.
Gary
Old Apr 18, 2002 | 09:00 PM
Phate's Avatar
Gary,
My car is an Incon car, but the turbos are off for warranty repair right now, so I am going to practice tuning the car on the motor with the wideband.
I guess I will call some tuners and see where they recommend putting the sensor...I will also probably wire in a set of EGT's once I get a chance...but my main tuning will be with the WB!
I am pretty excited about getting it installed... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I'll try and take some pics of the install...I was thinking about making it removable so I can use it on a few different cars for tuning. I would definitely have it in my car for the track though!
Scott
Old Apr 18, 2002 | 10:56 PM
Futral's Avatar
With a true heated wide band sensor,location is not that critical.I like to install them about 12-18 iches from collector inlet from the primaries.Just depends on which location is best for you or which side of the motor you wish to monitor.
Old Apr 18, 2002 | 11:38 PM
Phate's Avatar
So it doesn't really matter which side?
So it would be better to put it in the junction of the Y-pipe so that I could get readings from both sides?
Scott
Old Apr 18, 2002 | 11:59 PM
Futral's Avatar
You could if you wanted to,no problem.
Old Apr 19, 2002 | 12:11 AM
Phate's Avatar
Coool!!!
Thanks a lot!
Scott
Old Apr 19, 2002 | 12:15 AM
red ws6 99's Avatar
I have the FJO got it from Alamo also. I did not get a the display, just the rpm pickup, etc and the pc interface. I have not installed it yet, but its going to be installed in the glove box. I am looking at building a switcher so that I can run two sensors off one box. Then I would just use the aux 0-5 input to know which sensor it was reading. So the switcher box would output 1 volt when sensor 1 had power and 2 volts when sensor 2 had power. Not sure if really need this, just thinking about it though.
Gary
