Help - Need to Convert From MAFT Settings To LS1Edit
Old Apr 25, 2002 | 07:37 PM
Sparky's Avatar
Default Help - Need to Convert From MAFT Settings To LS1Edit
Guys:
I'm ready to take my maft out of the loop. My readings are currently set to 5% rich at cruise and 4% lean at WOT.
What is the best way (and what do I modify) to remove the maft and come close to my settings?
Thanks!
Mark
Old Apr 25, 2002 | 11:16 PM
ChrisB's Avatar
Default Re: Help - Need to Convert From MAFT Settings To LS1Edit
you can scale the maf table by 105% to get your cruise increase. For WOT fueling use the PE vs RPM - but a 4% decrease there (scale by 96 or so) will not be equivalent to a 4$ MAFT settings - I would start out at around 95% scaling on the PE vs RPM table and keep going fo there. Dyno with a wideband is the best bet.
Chris
Old Apr 26, 2002 | 10:02 AM
Sparky's Avatar
Thanks Chris,
Sounds like this will give me a good start!
Mark
Old Apr 26, 2002 | 03:55 PM
John B's Avatar
Moderator
ChrisB
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">you can scale the maf table by 105% to get your cruise increase</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Why would you use the MAF table and not scale down the injector flow by 5% (multiply by 95%) to add fuel?
Old Apr 27, 2002 | 09:51 AM
ChrisB's Avatar
You could of course do that - but the injector constant is something you can *know* - it's a fixed value which can be calculated easily. The MAF table, once you change your induction from stock, is off. A lid, air intake, removing the screen, etc. all effect the transfer function.
I just personally would alter the table that is no longer accurate - but it doesn't really matter in the long run - there are more than 1 way to do everything.
Chris
Old May 6, 2002 | 09:59 PM
Scalpel's Avatar
Ok, on my MAFT with SVO 30's I have my base set so I'm at -3 and WOT at .90 (but the latter is mute right now). With my LS1Edit should I adjust my MAF tables or SVO's first? Thanks.
