Cannot get a-tap to connect.....WTF
Old Apr 27, 2002 | 11:39 PM
Damian's Avatar
LSX Mechanic
Default Cannot get a-tap to connect.....WTF
No matter what cable or laptop I use, that fuggin software just won't connect. I have tried 2 different cables and 3 different laptops. My port is not damaged, and I have got it to connect before but it won't stay connected very long. This is pissin me off.....
Josh
Old Apr 28, 2002 | 06:08 AM
98TAauto's Avatar
Default Re: Cannot get a-tap to connect.....WTF
are you using the cable they sent? or do you have a USB port adpater?
my USB gives me fits(POS) and it sometimes takes me 4 tries to connect..
i have to use a USB adpater cause i dont have the right one on the puter to work with the one they send
Old Apr 28, 2002 | 07:35 PM
Silver99Z's Avatar
The day I received AutoTap, I called the factory with a question. After answering the question, the factory guy asked me which software version I was using. He said that the latest Windows version has bugs and to download version 1.11 - I sometimes have to try a couple times before it connects to the PCM. My laptop has a serial port.
Old Apr 28, 2002 | 09:35 PM
Glenn98ZM6's Avatar
if i remember right, a blown fuse will cause that. something like the power seats, or something.
Old Apr 29, 2002 | 07:55 AM
jpatrick's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Damian:
<strong>No matter what cable or laptop I use, that fuggin software just won't connect. I have tried 2 different cables and 3 different laptops. My port is not damaged, and I have got it to connect before but it won't stay connected very long. This is pissin me off.....
Josh</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">When you connect to your vehicle it is best to turn the key to the on position, then plug in the Autotap and start the software. Joe at Autotap tech support is very quick and good. I suggest that you contact support@autotap.com to get your problem solved.
Jeff
Old Apr 30, 2002 | 06:15 PM
BLUEBYU's Avatar
All of sudden the laptop won't hook up with the car???? I just read in the previous reply that a blown fuse would cause this. Well, I just burned out or blew out 2 new front corner bulbs (turn signal) I just installed. They were the super white blue color. I thought it looked pretty cool with clear lens I just installed (BTW, piece of cake)....until they blew! I guess the hi-reflective internals in the lens create too much heat for the bulb. So went back to a long-life OEM replacement and they work... I don't seem to have blown a fuse and everything works...I think.
Any ideas would be appreciated.
Later, Randy Hughes
Old Apr 30, 2002 | 06:25 PM
ChrisB's Avatar
Is it detecting the module, or just not connecting
Chris
Old Apr 30, 2002 | 06:39 PM
BLUEBYU's Avatar
It's indicating it can not locate a port to talk to the car. I tried all ports....no go.
Old Apr 30, 2002 | 07:20 PM
BLUEBYU's Avatar
Just tried installing it with the instructions to the "t". Still no go...s#!t!!! I usually can figure this s#!t out....now, where is ATap's number...of course to late to call. Any ideas tonite would be appreciated..."I got that loggin' feelin'" great stuff...when it works, huh.
Ba-bye
Old Apr 30, 2002 | 07:23 PM
Mongoose Z-71's Avatar
Seems like A-Tap means problems for a lot of people. Sure glad I have EASE <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 30, 2002 | 09:21 PM
BLUEBYU's Avatar
Not looking for comparisons...just help.
Old May 1, 2002 | 10:49 PM
BLUEBYU's Avatar
Blew the fuse for the cig lighter....wouldn't advise an aftermarket lighter with the ATap module. The same fuse for the data connector. The billet lighter looked good...but oh well, ATap is better.
Old May 2, 2002 | 06:59 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
So you're connecting now? The same fuse as the cigarette lighter powers the (cars')port?
Old May 2, 2002 | 07:12 AM
Glenn98ZM6's Avatar
Old May 2, 2002 | 04:07 PM
BLUEBYU's Avatar
Yep, same fuse. I haven't tried to connect yet, but should be ok. As a side note...EASE would have had the same problem. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
