WTF is this...
Old May 14, 2002 | 10:31 PM
BYBYC5's Avatar
*Bad Trader*
Default WTF is this...
DTC Title
General Motors P1133 HO2S Insuff. Switching Bank 1 Sensor 1
i got this code today what the hell is it?
Old May 15, 2002 | 12:10 AM
ChrisB's Avatar
Default Re: WTF is this...
An o2 "switches" when it's voltage value crosses the stoich point - (450mv).
There are predetermined values for how many times an o2 should switch, or cross this point in a given time period. When the o2 doesn't meet the criteria the code is set.
If your o2's are old I would replace them. If they are new then it could be a sign of an exhaust leak - esp. with slip on type collectors.
If you are only getting it on one bank you can try swapping banks and see if the code follows the sensor or stays with the bank.
Chris
