LS1 EDIT and Torque Converter????
Old May 27, 2002 | 01:23 AM
02BlackWS6's Avatar
Default LS1 EDIT and Torque Converter????
Why doesn't LS1 Edit lock my converter up? The table shows it's supposed to lock it up at normal driving around 42 mph. But my Vig. never locks up. Does anyone know how to get EDIT to lock my Vig. 3600 up??? I guess what i'm getting at is the when i use a stock A4 program and use EDIT my converter never locks up. With my custom non-LS1 EDIT tuning my converter locks up fine. But i'm trying to get the most out of my LS1 Edit.
Den
<small>[ May 27, 2002, 01:52 AM: Message edited by: 02BlackWS6 ]</small>
Old May 27, 2002 | 10:50 AM
msce2b-dustin's Avatar
Default Re: LS1 EDIT and Torque Converter????
Have you trid lowering the lockup point. My tp4400 didn't want to lock up until I lowered the mph quiet a bit.
Old May 28, 2002 | 02:29 AM
ChrisB's Avatar
Have you deleted the p0300 code/changed the misfire enable temp to a high value?
If not try that and see if your TCC will engage.
Chris
Old May 28, 2002 | 03:03 AM
02BlackWS6's Avatar
I haven't tried lowering the lockup value, but i'll give it a try. I did delete the p0300 code.
But thanks for your ideas.
Den
Old May 28, 2002 | 10:26 AM
Ryan K's Avatar
Pathological Modifier
Change the Enable temps for the misfire detection. Have the computer enable at 142 and disable at 141 or vice versa. It is not the same as deleting the code.
Ryan K.
Old May 28, 2002 | 11:39 AM
ChrisB's Avatar
Yep, make sure you have increased the enable temp (as mentioned above) also.
Chris
Old May 28, 2002 | 11:50 AM
02BlackWS6's Avatar
The highest valve EDIT allows me to change it to is 150. If i try to change it higher it says out of range. Under what section can i find the Misfire enable??? Is it under the "Diagnostic" section?? Is has a Max. temp and a Min. temp setting. So i need to raise the Min. temp to 142?? The Max. temp is default to 142 already, and it only allows me to change it to 150 max.
Den
<small>[ May 28, 2002, 11:58 AM: Message edited by: 02BlackWS6 ]</small>
Old May 28, 2002 | 04:21 PM
02BlackWS6's Avatar
TTT
Old May 28, 2002 | 07:54 PM
ChrisB's Avatar
just set the min temp to 150.
Chris
