(Possible?) Wide band O2 solution using existing PCM
Using LS1 Edit deactivate the codes for the rear O2 sensors and replace the stock sensors with either wide band O2 sensors or 700mv-1mv narrow band O2 sensors. Then use your scan tool to monitor them.
Thanks
John
The NTK units commonly used are 5 wire units with a 0-5v output range. There is also the issue of the heater control circuit which much maintain a constant temperature (the o2 output is very temperature dependant).
If your control circuit/box re-scales the output to a 0-1v input and you have a translation table for the corresponding a/f ratio you could do this - but you would be giving up a good bit of resolution. For data logging using a 0-5v sensor would be a better choice (AC pressure maybe?)
Bosch makes a LSM-11 sensor which is supposto be an accurized standard type O2 sensor. It will still require precise heater control though, so will still need some sort of control box.
Chris
Surely someone can come up with better price. We all need this bad.
ERic
I am just a loly mechanical engineer if you know someone with electronics and programming experience (can do the programming maybe) let me know I can get them pointed in the right direction. I just dont have the time to develop the stuff, to busy building a turbo system.
Gary
wizkid:
The best thing to do is really to find a 0-5v input on the vehicle. On LT1's the AC pressure sender is 0-5v and can be adapted for this (as it causes no problems when unplugged (unless you turn on the AC - the the clutch probably wont engage)).
If you do it like this then you are keeping your time domain constant for all sensors - e.g. at a given datapoint you know all sensors are in phase with the wideband reading. It also simplifies the entire data collection process as you just log like normal with whatever software you use.
Chris
Gary
So you will need a circuit that will maintain a constant temperature based on the current draw of the sensor. Current flow will change based on the exhaust temperature (WOT, cruise, rich, lean) and the installation location of the sensor.
What is the voltage resolution (.0, .00) of the AC pressure sender input on the PCM?
What would be the best O2 sensor to use?
The O2 sensor is ~$140 at NAPA.
The link to DIY-EFI above has a lot of good info.
I wonder how well it works?
Thanks
John
<small>[ July 17, 2002, 10:44 AM: Message edited by: JNorris ]</small>
