want to find out my timing using autotap. help please.
I want to find out what my timing is at using autotap. I know I have to go to ignition timing. I want to know if the timing was dropped for the n20. if it was I'd like to get it raised so I can run N/A until I get my fuel system upgraded. in a couple of weeks. I wanna go to the track and see no point in having my timing dropped if I will be running N/A. how do I do it? thanks
Re: want to find out my timing using autotap. help please.
Do a run logging RPM, timing, knock, and TPS. Look at what the timing is when you are at WOT and if you are not getting any knock (pulls timing) thats what you timing is set to.
