Jet-Hot LTs + Denso 'vette rears = ...
#41
Originally Posted by SideStep
Ah... I was wondering how come LG never sales the adapters to F-body owners... ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I picked up a pair of 13111's yesterday. I'm not going to install them yet cuz I think I have a tiny exhaust leak near both sensors, and/or contamination. I got p1133 and p1153, that's both sides
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
I can't find the leak though
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I did use a good amount of sealer on the collector joints but it was sensor-safe sealer.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I also used some aluminum tape on the collector joints. I wonder if the adhesive from this tape has containated my o2's. I'm not having fun!
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
I might just clear the codes and drive it some more and see what happens.
#42
Originally Posted by SmokingWS6
F-bodies use the Square connector. Vettes and trucks use the flat ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
thought mine weren't wiggly enough awhile back, so i swapped in a set of the 13111 sensors. after a couple days had to go back to the stocker denso's. i only "thought" they weren't wiggly enough. the bosch's just didn't work for me in this case.
#43
something you guys all need to realize is that it doenst matter what o2 sensor you are using..if its a narrowband..heat(or cold) affects how it operates...
it doesnt necessarily need to switch in a nice sine wave pattern...as long as its switching...
alos if you have done anything to your vehicle...then there is a good possibility that 14.7 is no longer your o2 switchpoint value...
it m=is most liekly a higher value..
meaning stock switchpoints may be in teh 450-550 range dependent on several things....and setable in a table in your pcm,.....
but with any mod that same switchpoint may need to be higher to = 14.7...meaning that it may need to be more like 550-650 or higher!!!..
in my own personal vehicle (2000 camaro SS with longtubes, duals and an intake) my o2s switch closer to 750-850 to = 14.7(checked on 2 different brands of wideband with differernt o2 sensors)..
I wont see a nice cine wave on my scans..but I will see stft's switching back abnd forth from + to - values...
this is more of what you should watch...if stft's arent going back and forth then you have issues...
#44
Originally Posted by MeentSS02
My Bosch sensors took a **** a few weeks ago on me on my Kooks headers. Been running open loop ever since...I'm not gonna go back to closed loop until there is a better solution available. It is too much money to be throwing around at pure conjecture and hearsay.
#45
Originally Posted by 98A4LS1
I have to agree. 1000 miles on Bosch 13111 and Bank 1 O2 sensor is already taking a dump. $75 a pop every 3 months sux.
