Top Speed?
Old Jul 25, 2002 | 05:20 PM
ZeeQuick's Avatar
Default Top Speed?
How fast will the stock computer allow an LS1 to go before shutting off the fuel? Some guy told me it was 105mph.
Old Jul 25, 2002 | 05:46 PM
Predator's Avatar
Default Re: Top Speed?
I think the cars that come with non Z-rated tires are about 105mph (not sure exactly), but my car was limited to 160mph as I discovered by reading the stock pcm file with LS1 Edit. My car originally came with Goodyear GSAs which are Z-rated.
Old Jul 27, 2002 | 01:43 PM
99SICKSPEEDZ's Avatar
I was told by gm that the cut off was 137-138 mph. You can buy the programer to go around that. I just set mine to zr rated tires which is 255 mph. Wont be going there!!! It depends on the year of your car they where all set diffrent.
Old Jul 27, 2002 | 04:20 PM
01Z0H6's Avatar
Have had mine to 152....... A4 w 273's <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Jul 27, 2002 | 11:48 PM
RUF SS's Avatar
A Z28 Camaro with Z rated tires will go about 160MPH than the computer will cut off the fuel.
I say "about" because it is not that accurate, you could hit fuel cutoff between 157 to 163.
Also, 99% of F-Bodys will go over 160 MPH Without a speed limiter.
Old Jul 30, 2002 | 01:16 PM
ZeeQuick's Avatar
Well, i have a '98 without Z-rated rubber. I guess i could just find out if its limited on my own <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . I don't have a programmer though so i can't change the max speed right now anyways
Old Jul 30, 2002 | 06:45 PM
NTMID8's Avatar
I've been beyond the 155mph limitation of my speedometer without reprogramming anything. Mine is a '99 Z M6 with 3.42.
