ABS inop, and ASR off
Old Jan 16, 2006 | 11:39 PM
67Ranger's Avatar
Default ABS inop, and ASR off
I finally got my car started today after sitting for about 8 months. Put a new 370 heads/cam, blah blah blah. Anyways, i was out breaking her in. I drove around for about 20 mins, and then all of a sudden my ABS inop light, and my ASR off lights are on for no reason. I cant get the ASR back on with the button, and the ABS doesnt seem to be working either. Whenever i turn the car off, and start it back up they go away, but then my low traction light comes on, and whenever i try to get going, my traction control comes on, and does its little deal, and whenever i hit the brakes, the ABS comes on and makes it real akward to stop. After a couple stops, the low trac light goes off, and the ABS inop, and ASR off lights come back on. Does anybody know what could be causing this, and if it would come up with a handheld scanner? I was thinking maybe the wheel speed sensors, but they are all hooked up, and seem to be working alright. The only other thing that might affect this is that i put a new wheel stud on one of my back wheels, im not sure if that would make a difference though. Thanks for the help, and sorry for the long post.
Clif notes: ASR off, and ABS inop lights are on. What could be causing this?
Old Jan 17, 2006 | 09:46 AM
jimmyblue's Avatar
Moderator
If the wheel stud is not pulled all the way through
it might be upsetting the sensor chopper field
signal and giving the ABS false wheel speed.
Old Jan 17, 2006 | 12:33 PM
67Ranger's Avatar
hmmm... we pulled it through about as far as the others using an open ended lug nut, and an impact gun. I'll check it out whenever i redo my brakes soon.
Old Jan 17, 2006 | 07:37 PM
67Ranger's Avatar
I just talked to the person who helped me put it on, and he said that he double checked, and it was through all the way. Anyone hav any other ideas?
Old Jan 18, 2006 | 07:28 AM
weestro's Avatar
You might pull the speed sensors and clean off the magnets. It sounds like the system can't get a consistent reading. Mine flips out as well but only over 70MPH.
Old Jan 18, 2006 | 10:09 PM
67Ranger's Avatar
that would probably help, since there is quite a bit of dirt/dust around them. What should i use to clean them? Would canned air work alright, or a liquid cleaner?
Old Jan 18, 2006 | 10:47 PM
weestro's Avatar
I'd use some brake cleaner, that'll get 'em.
Old Jan 19, 2006 | 08:25 PM
67Ranger's Avatar
alright... I'll try that tomorrow.
Old Jan 19, 2006 | 08:52 PM
Full-Force's Avatar
Mine has been doing that lately. When I crank my car sometimes my asr off light will come on and the asr button will not work. I might drive a few miles and it will come back on.
I dont remember it doing it before I put my linelock on my car, but that may just be coincidence.
Old Jan 19, 2006 | 10:44 PM
Quickin's Avatar
If I'm on the highway for more than 1 hour cruising above about 75mph, they come on and stay on until I turn the car off, than back on.
wierd.
Old Mar 16, 2006 | 11:25 AM
LANDONZ's Avatar
where is this speed sensor at? I put new studs on both of my front wheels and my ABS INOP/TCS OFF lights have been on. That might be my problem cause I have cleaned the little plug things twice thinking that would fix it
Old Mar 16, 2006 | 03:57 PM
2000Z28M6's Avatar
My absinop light just came on yesterday, for no reason. I was just driving along. About a yr 1/2 ago same thing happened and it turned out to be a bad wheel speed sensor. So im thinking this time its the same thing, I talked to brake check they said they will inspect it for free and tell me whats wrong with it. I like the sound of that, if they can tell me what sensor is bad I will replace it myself.
Hope they can do that.
Old Mar 17, 2006 | 05:41 AM
ninobrn99's Avatar
after installing my new 9" mine started doing the same thing, but at all speeds. Someone told me that they had the same issue and that it was their wheel studs causing interferance with the readings. I was told to get about 1" of pvc pipe, and place the sensor in it, use 4 small washers to move the sensor back and clean it. havent had a chance to do it though. i hope it works.
Old Mar 17, 2006 | 02:41 PM
VORTECFCAR's Avatar
mine does this too...
strange 12 bolt with 3.73's also.
weird
Old Mar 18, 2006 | 01:50 AM
ninobrn99's Avatar
will someone try to spacer thing to see if that helps? its annoying!
heres what i got im an email on what to do:
Originally Posted by bigdsz
The washers I used were maybe 7/16 to 1/2" in diameter and maybe alittle less than 1/16" thick. I used about 3/4 of the piece of PVC to get it actually around the magnetic pick up. Once you get uder the ca and play withit you'll see what yo need to do. Your ultimate goal is to get the magnetic sensor far enought from the stud bolt heads so that they don't create an additional electric field and **** up the abs readings. Hope this helps.
Old Mar 18, 2006 | 10:06 AM
2000Z28M6's Avatar
Sorry to say, yesterday before I got a chance to check it, the ABS INOP light just went off, WTF????Well I'm not going to worry about it for now! Crazy
Old Mar 18, 2006 | 07:12 PM
67Ranger's Avatar
mine fixed its self at the race track, after a few nice burnouts... may want to try that.
Old Mar 18, 2006 | 07:42 PM
crazy camaro's Avatar
if you do fix the problem it takes 300 key cycles to let the light reset i had bad wheel speed sensors and it did that i also have a strange 12 bolt and the screw in studs backed off a bit that was also a problem too
