Is it safe to change Open Loop fueling...
I want to alter the cold start to something elss cylinder washing, like 12:1 (or leaner if it safe) and gradually lean it out as it gets warmer. Any issues doing this?Charlie
you are indexed up in MAP to some really high enrichment.
If you look at the rows about 30-35kPa, which is where
stock A4s idle, that's probably the enrichment you want
at whatever your monster-cam idle MAP turns out to be.
Note that leaner will also idle at lower MAP, and richer
further elevates MAP / depresses vacuum which is part
of the reason for piggy idle richness, some positive
feedback (in a negative sense) there.
I think what your saying is: Yes, guys with larger cams may need to decrease the OL AFR Modifier. How low? Use the 30-35kPa modifier as a base starting point.
Good tip!
Esentially, this will lean out the idle mixture across the board. Since my MAP readings never fall below 40 kpa, and my 120-192 *F idle MAP is 58-60 kpa, I should be safe right?
What I did notice however, is that at startup, my map readings were 99 kpa for the first 7-8 seconds. It seems to me that it would make more sense to reduce the values in this table more at the 90-100 kpa range. Maybe I'm way off base, maybe Horist or Jimmy can chime in again.
