Can you delete the AIR pump with LS1Edit?
Old Aug 12, 2002 | 02:12 AM
MMI Z28's Avatar
Default Can you delete the AIR pump with LS1Edit?
anything else i can just take off all together?
anyone give me more info what all i can change\delete off a PCM wiht LS1Edit.
BTW this is for a 01 LS1
-Watson
Old Aug 12, 2002 | 03:52 AM
DCPunkSteve's Avatar
Default Re: Can you delete the AIR pump with LS1Edit?
From what I've heard, you can delete the AIR and EGR, but I haven't actualy used it yet, so I could be wrong, but I'm pretty shure I'm right! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 12, 2002 | 07:12 AM
MIGHTYMOUSE's Avatar
of course you can remove:
air pump
egr
cags
vat
speed limiter
rev limiter
maf limiter
knock sensors
rear o2's. etc.
you can even tune to remove your mass air sensor if you want to <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
*i dont reccomend removing some of the above, but its possible and more*
Old Aug 12, 2002 | 01:37 PM
MMI Z28's Avatar
what is the MAF limiter?
Old Aug 12, 2002 | 01:43 PM
GeorgeC's Avatar
Hell, if you're crazy enough, you can remove the front O2's and run the car in open loop all the time <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 12, 2002 | 01:45 PM
NoGo's Avatar
I have a question to add to this actually.
Is there a way to stop the air pump from turning on. My air pump is disabled in the engine diagnostics, but still connected, and it still comes on. I know that I can pull the fuse, and wiring, but I would rather find a switch in edit that keeps the pump off.
Any suggestions?
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ August 12, 2002, 01:47 PM: Message edited by: NoGo ]</small>
Old Aug 12, 2002 | 01:51 PM
move the air pump 'on' temperature to 150*C i forget which section thats in, one of the first ones i believe
then remove it from the car.. thats the idea <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 12, 2002 | 07:56 PM
NoGo's Avatar
Thanks for the info
