Battling Knock Retard... Is if False?
When I am at the track I run Sunoco 94 with a bottle of NOS Off-Road Octane Boost, my engine is 11.5 CR, and I have LS1edit so I have played with the timing advance and set it anywhere from 24 degrees down to 19 degrees from 4200rpm - 5500rpm and the KR still happens. Even though I get quite a bit of KR, I NEVER EVER hear a sound out of the engine, and I cannot feel it stumble like an engine normally does when detonating.
Does anyone feel this might be false knock retard? Where would I start looking if it was? Would it be wrong for when I go to the track to turn down the Max KR by RPM to like 3 degrees?
When I am at the track, with 8-9 degrees of KR, I am only pulling like 12 degrees timing advance which is terribly ripping down my trap speeds by at least 5 or 6mph.
Anyone else ever encounter a problem like this? Any experiences someone could share would be greatly appreciated
I removed my lid, 85mm maf, htpp tuning, iat!, and holly air filter.
I have used two cans of gm top engine cleaner. One can of seafoam and added a can to my gas. I think the seafoam works the best, I could tell a difference in the way the car runs.
One thing you must do is stop the oil from getting in to the intake. I tried smh mod “it help but did not stop all of the oil” I have an air compressor filter installed right now and it seems to work. I can send you some pictures if you like.
-hook up a fuel pressure gauge to fuel rail; make sure you are seeing over 50 lbs., preferably around 55.
- check injector pulse width with atap. under WOT i think you want to see 19-22.
if both of these tests are within safe zones, you should check to see if any exhaust components or suspension pieces are banging the chassis. if still nothing, try nineballs KO box to desensitize the knock sensors.
good luck!!!!!!!!
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">reduce the total number of degrees that the knock retard can take out of your timing (max retard vs. load table)</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">increase the "Decay vs. RPM" values by ~150% to return to stock timing faster once KR is sensed</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">Reduce values in "attack vs. RPM by ~50% to slow down how much the KR comes on</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">copy the values from your high octane table and type these into your low octane table (this is a pain because you cannot import the numbers, they have to be typed in)</font></li>
1) Try richening the PE vs RPM by a fixed amount (so you can take it back out later if needed). Say increase it by 110-115 percent. This should knock you down a full a/f point richer.
2) Fill up with 104 unleaded.
If you are running verifiably rich and with 104 and still getting the same amount of knock retard I would suggest some sort of false reading. First I would replace the knock sensors and torque them to spec. If that doesn't help I would start adressing an "overly sensitive" knock sensor through programming.
Chris
