question about positive LTRIMS at WOT
should i adjust my Ltrims going off of the 1.5+ on regular driving or should i lean it out about 6% becuz its about 5+ at wot?
the reason i ask this is becuz ive read alot of stuff lately about ltrims at wot
thanks
<strong>My Ltrims are averging around 1.5+ on a 20 minute drive, but at WOT they are 4.7+ and 5.5+. does this mean they are adding that much more fuel @ WOT? and if so, does that effect the 02 reading in anyway?
thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Most people find tuning with the LTFT positive is a pain in the ***, for the same reasons you're talking about. That's why people usually get them to be slightly negative.
Anyway, your O2 readings will reflect the +4.7 and +5.x, so if you're running okay with those, then you don't really have to worry about it.
http://www.c5forum.com/diy/ltft.php
<small>[ September 09, 2002, 05:02 AM: Message edited by: Orange Krush ]</small>
at WOT my ltrims now are about 3+
AS LONG AS YOU SEE LTERM VALUES WITHIN THESE RANGES, YOU ARE NOT DAMAGING YOUR CAR <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> because you are still maintaining the target a/f ratio of 14.8% Too many poeople get concerned with trying to dial in their LTerms to exactly 0.
The way LTerms contribute to WOT is that positive LTerms are added to the current Power Enrichment at WOT. This makes it a total pain in the **** to tune WOT because depending on what the Lterms were when the car went WOT your WOT a/f ratio will be altered accordingly. If the Lterms are negative when the car goes WOT, then the Lterms are dismissed.
And the clencher... Unless you are running without cats with the cat overtemperature protection off, then IMO you are wasteing your time. As long as your CAT overtemperature protection is in (which you need if you have cats), your car is going to get tanked to a low 11 a/f ratio anyways at WOT to protect your cats, so getting your Lterms to slightly negative won't make a difference anyways.
Just make sure your Lterms are within +/- 10% and call it a day. (Until you pull the cats)
<strong>The way LTerms contribute to WOT is that positive LTerms are added to the current Power Enrichment at WOT. This makes it a total pain in the **** to tune WOT because depending on what the Lterms were when the car went WOT your WOT a/f ratio will be altered accordingly. If the Lterms are negative when the car goes WOT, then the Lterms are dismissed.
Just make sure your Lterms are within +/- 10% and call it a day. (Until you pull the cats)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks! Haven't heard it put quite that succinctly before! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Dude, go one more click positive on your MAFT BASE. This will add more fuel and force your fuel trims to back off. It should put you into the negative trims. For some reason the engine always runs better when pulling fuel than adding it. When doing this Keep your WOT set at 0 till your BASE trims stabilize (10 or 20 miles) Then run a new tap and see where wot needs to be. You may not even need to add any more at that point.
I used to run +5BASE and +6 on WOT I had positive fuel trims and no knock but the motor did not feel "SPUNKY"
I since changed to +10 on base and 0 on WOT, now I get a negative fuel trim and very little (1 or 2 degrees) K/R on WOT. The motor is very spunky now. I may just pop the WOT one click...
i have it set at 8% more right now on base, and im getting .8 ltrims at WOT, so i got it down alot,im going to try 9% and 10% to see if that will take care of it.
let you know if it works
<strong>i dont have MAFT anymore, i have ls1edit,
let you know if it works</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah, that's he nice thing about LS1-EDIT... The granularity down to 1%. The MAFT was 5% every time... <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
I should have my LS1-Edit in a week or 2... I can't wait... Goodbye MAFT
<strong>I am a bit confused about this cat thing and wot..I can dial my car down with my maft and the o2s stay down..I can change my air fuel as evidence by increasing knock when I got leaner and car feels different at different settings and gets slower too rich..I have seen lots of dyno graphs with cars at 13.1 wide open and some of those have cats..so how can the cars be running at like 11.7??? Makes no sense..anyone else know something about this....are you telling me my cats will die running in the ideal 12.8 to 13.2 range..?? I had my car leaned down for many thousand miles before with my maft and stock cats with no problems....</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have gutted cats and O2 simms <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> So I dont have that problem. But once I get my LS1-Edit it's COTS disabled for me..
I wish I knew exactly how dangerous it is to let the CATS get hot...If it just wrecks the CAT who cares. I just don't want a fire under the tunnel <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
