LS1 Edit drains my battery?
<small>[ September 11, 2002, 06:06 AM: Message edited by: StevieZ ]</small>
BTW, how safe is a desktop PC for the same reason ? How is it guaranteed that all signal levels and overall grounding are within ballpark anyway ?
<small>[ September 11, 2002, 06:24 AM: Message edited by: pekkaz ]</small>
Next up, chargers.
A charger works by injecting current (and hence voltage) in to the electrical system. The charger introduces a ripple in to the voltage level. This ripple can cause weird things to happen, so that's why they recommend that you not use it.
When I was beta testing LT1_Edit, originally, the fans would run while programming. I killed my battery several times doing this too (on my 94Z). I also used to run a charger, and never lost a PCM with it, but I do understand why it's not a good idea (I discontinued that habit - and did replace my battery). But finally they figured out how to make the fans not run while programming, and battery drain was significantly reduced.
So, my recommendation is to replace that battery before it dies on you during an upload. If that happens, ewwwww....
-Andrew
<strong>So it sounds like the consensus is that this isn't normal and I need to replace my battery?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">just go to advanced and and get them to test your battery, or test it yourself on a tester. Mine was about dead the first time i edited so thats why it died. With me new one i probably dont need a charger while programing, but its just a peace of mind for me.
but if your battery was run dead, it probably wont hold a good charge, so it will die again soon
Hopefully the new battery will fix this problem. I'll be waiting until I get my new battery before I do any thing more with LS1 Edit.
but ive used a charger on LOW feed about 60times with no issues yet. But again its a use at you're own risk type deal
you should be more than fine programing your car 2-3 times without draining the power. Just start afterwards to let the battery charge up fully again
