can car be wb dynoed with duals under car?
Can they still hook up my car to a wideband dyno with my exhaust being true duals ending under the car before the wxle with turndowns?
thanks!
<small>[ September 15, 2002, 07:27 PM: Message edited by: terry99ta ]</small>
thanks!
Re: can car be wb dynoed with duals under car?
Depends on the shop. A good shop will have the capability of putting in wideband O2 sensors that screw in just like the stockers, but you need the extra bungs if you got rid of your post cat bungs. Other shops use a single wand. In theory you be fine in that both sides should be pretty close. you can always tune with one side and then make a pull switching the side to verify the results.
my exhaust will be
dynatech stepped headers
merge collectors
flowmaster 6" mufflers
turn downs
maybe I should put a bund in the rear of both with a plug?
merge collectors
turn downs
I put in extra bungs in my Y-Pipe for that. Its about $20 for the bungs and caps and probably $20 to weld them in. Call the shop that will do the wideband dynoing and ask what they use.
